Seafoam anyone?
Old Feb 6, 2008 | 03:50 PM
Zaairman's Avatar
I've used Seafoam in many engines and love it. Restores throttle response, lost power, and helps the engine run smoother. I say go for it.
Old Feb 7, 2008 | 10:58 AM
mrpositraction's Avatar
Originally Posted by chester8420
NO!! Just wash it off!!! Get all the crud and oil off of it! The reason is that if you ever have to add some in an emergency (like on the side of the road where there isn't a water hose) you won't get dirt in it!! Also, it's corrosive, and a clean resevoir makes it easier to notice when the oil gets low!!! Also, it may help prevent your truck from burning up (or blowing the fuese) due to oil in the switch.
Oh, that makes a lot more sense. Yes, keeping areas clean around where you add fluids is a good idea.
Old Feb 7, 2008 | 11:43 AM
jward's Avatar
Good info, Chester.
Read the owners manual and use some common sense.
WRT shocks, they rarely "wear out". The reason many don't make it to 50K miles is because people like the placebo effect. Lots think when they change out parts early, with stock or aftermarket, they are adding to the longevity of their vehicle. Same thing with "additives", high priced fluids, and filters. In most instances, it's a waste of money.
Old Feb 7, 2008 | 12:25 PM
Norm's Avatar
Nope. Just a quick search on here will show you how many people had bad shocks at low mileage. Ford shocks suck. If you can compress them by hand they are bad. Mine were bad at less than 40K.
Old Feb 7, 2008 | 12:35 PM
jward's Avatar
Norm, "suck" is subjective, dontcha think?
Shocks, by any maker, seldom wear out. A defective one is possible. Four on a vehicle? Buy lottery ticket ASAP!
BTW, "a quick search" on here says Mike Troyer is the greatest F150 tuner out there. But, you'll ONLY read that here.
Old Feb 7, 2008 | 12:40 PM
Norm's Avatar
Yes "suck" is subjective. 3 out of 4 of mine could be compressed by hand and 2 did not extend after I let go.
It is a fact that shocks DO wear out. I am surprised that you believe otherwise. This was discussed in depth on here years ago.
Old Feb 7, 2008 | 12:50 PM
jward's Avatar
Norm, maybe I mislead. Probably 95% of the people that post here will never put more than 300K miles on a vehicle. I have with 4. 2 trucks. 1 I still have and drive with over 430K+. I replaced the shocks on it at 200K. Made no difference in drivability. Couldn't tell by SOP. Have never replaced shocks on any other vehicle. Just my personal experience.
And after talking this subject over with dealership mechanics and friends at Midas, I think most people who replace their shocks, and other parts, do so way too early.
You had some bad luck with yours.
Old Feb 7, 2008 | 12:57 PM
medic's Avatar
FWIW, I replaced the shocks on my 97 at 100k miles and they were all shot. I could compress them all easily and they didn't even attempt to return the the extended position. With the new shocks (Monroe Reflex), I noticed a stiffer ride. If you want to get the maximum life from your tires and have as much control as possible, change your shocks! I really wouldn't say this if it wasn't true - the nut on top of those rear shocks is a real PITA to get off. I ended up using a plasma cutter. I haven't looked at my 06 yet, but I hope they made them easier to change.
Old Feb 7, 2008 | 12:58 PM
Norm's Avatar
I agree some are replaced early. I also have years of personal experience and have seen many failed shocks. As far as driveability goes most people do not expect a truck to ride like a car and may not pick up on bad shocks. I did.
Old Feb 7, 2008 | 01:58 PM
TheCure's Avatar
G'dam, people will argue about everything.
Old Feb 7, 2008 | 02:10 PM
Yes we will, what else is there to do on the internet?
Old Feb 8, 2008 | 02:56 AM
chester8420's Avatar
Originally Posted by glc
Chester, the bearings should be preloaded. The way I do it is spin the rotor while tightening the nut with a wrench, then stop spinning and loosen it 1/2 turn, then finger tighten it and do the retainer and cotter pin.
Yeah, I tried to describe how to do it... But the main problem people have, is that they get them TOO tight. It the worst thing you can do to a bearing.
Originally Posted by Norm
Ford stock shocks suck. Very few get beyond 50K. The Ford/ranchos are not much better.
You are very lucky I guess or they used better shocks in 97. I could compress 3 out of 4 of mine by hand and 2 of those did not return to their starting position after I let go. I had less than 40K.
Amazing! Yeah, well, I just knew that the truck would ride like a dream when I replaced them, and I forked over some big dough at the dealership for the factory heavy duty ones. I couldn't believe it when I took the stockers off. They had the same resistance as the new ones!!! I actually put them in a pile in the corner of the shop, in case one of the new ones breaks, or starts leaking. It made no difference whatsoever (as far as ride quality).
Old Feb 8, 2008 | 03:03 AM
Well, not exactly. Shocks don't actually help to hold the truck up, they just dampen suspension movement. You actually HAVE to compress them by hand to put them on the truck...
If they slide easily and quickly in and out, then they are JUNK. But if they offer stiff resistance, and move slowly when you push them in or release them, then they are fine. I've never heard of one that didn't spring back to the long position... You must have been jumping too many ramps!!!! Or I guess I just got lucky. You want me to send you my old junkers Norm?!!!
Old Feb 8, 2008 | 08:33 AM
Norm's Avatar
Good to see you still have that sense of humor Chester!
There is a difference in pushing them easily and the force needed to compress new ones. I put Bilsteins on and have not looked back.
Old Feb 8, 2008 | 09:40 AM
jbrew's Avatar
Yea , I tell you what , I didn't think there would be THAT much difference.
After I installed the Bilsteins - Major difference!! Wished I would have did that the day I brought home from the dealership.
