2000 4.6L Problems.
Old Feb 3, 2008 | 08:44 PM
baticus's Avatar
2000 4.6L Problems.
As of right now, no engine lights have came on. But when I idle the truck, its got abit of a miss, causing the engine to give off a vibration when you rev it up. Its mostly apparent in lower RPM's, and more noticeably when I'm driving it. But its not happening 100% of the time. Which is throwing me for abit of a loop. The truck has a M5OD, and less than half a year ago we had the clutch replaced.
Old Feb 3, 2008 | 08:53 PM
built54's Avatar
have you recently washed the engine?
Gotts2BMe's Avatar
How many miles on your ignition? It may be time for a tune up
Old Feb 3, 2008 | 10:42 PM
baticus's Avatar
Haven't washed the engine recently. There is currently 220,000km on the truck, and we've had it since 160,000km.
Also, the first time I noticed it, as the problem has been intermittent, was when I noticed I was alittle low on oil, so I topped it up, using 1 litre. The truck couldn't go faster than 80km/h without violently shaking, problem seemed to dissapear when I took the litre of oil back out. That was probably a month and abit ago. Now I have the same vibrations, only not near as bad.
I'll probably end up swapping plugs on it within the next few days, and see if it gets any better.
Old Feb 4, 2008 | 01:21 AM
JMC's Avatar
JMC
25 Year Member
I have 214,000 km on mine. I swapped engines about 60k ago but kept the 4.6 coils. About 2 months ago It would sputter when it was below freezing till the truck warmed up. I replaced the coils in Jan and the cold engine sputtering has gone.
JMC
PS. It is a good idea to check the plugs to see what condition they are in.
