Are They All The Same?
Old Jan 25, 2008 | 06:20 PM
NothingButFords's Avatar
i have a 1938 Ford 2ton the i'm restoring into a hotrod and i want to put a farily big engine in it. i'm using the real body not a fiberglass one so its heavy, and i was wondering can i only put a certian engine in it made for trucks or are they all the same?
Old Jan 25, 2008 | 06:24 PM
there were alot of different "modern" modular motors
97-2000.5 4.6 non PI
2000.5-2003 4.6 PI w/ traditional throttle
2004-2008 4.6 PI w/ fly by wire
97-2003 5.4 2v w/ traditional throttle
2004-08 5.4 3v w/ fly by wire
Old Jan 25, 2008 | 06:27 PM
whats an engine that doesn't have a lot of electrical, and will give a lot of power. is fuel injected or carb better
Old Jan 25, 2008 | 06:30 PM
Not alot of electrical you might look at the I6 from the previous 90's body truck or the 351 from the same years. and that would be with a distributor, and injected if you get one from 89 or newer
Old Jan 25, 2008 | 06:32 PM
Faster150's Avatar
they make carb intakes and distributor setups for the modulars now.
Old Jan 25, 2008 | 08:27 PM
Veteran: Army
a 302 or 351 Windsor with a C-6 or AOD trans is a fairly common swap.
a 460 with a stroker kit and a dual carb tunnel ram will yield lots of power
Old Jan 25, 2008 | 08:29 PM
Veteran: Army
what engine did it have originally? what kind of factory motor mounts are on the frame? if you have the Y-block motor mounts (2 on the bellhousing and one on the front timing cover) than you will be limited without a conversion crossmember of some kind
Old Jan 26, 2008 | 12:40 AM
well i was planing on buting a frame or getting one made custom so that i could put in whatever i wanted and just start from scratch. and just use the body.
Old Jan 26, 2008 | 02:40 PM
chris1450's Avatar
If your going to start a frame from scratch, then you can put anything you want in it.... just keep it ford! least electrical: distributor and carb. More electrical, modern and cool: injection. Your choice of style.
Old Jan 26, 2008 | 04:29 PM
k
thanks
Old Jan 26, 2008 | 05:06 PM
Veteran: Army
I agree, look for a donor truck and just rebuild the drivetrain that's allready set up for the frame
Old Jan 26, 2008 | 05:43 PM
F151's Avatar
I believe a PSD is in order for this application.......
Old Feb 1, 2008 | 07:01 PM
sorry i'm new at this whats PSD?
Old Feb 1, 2008 | 08:15 PM
Veteran: Army
wow, did you read the email i sent you???
why ask for help then ignore it??????????????????
PSD = power stroke diesel
Old Feb 1, 2008 | 10:46 PM
no no i read it but i didn't think that it was on there
i did read it
