chirping
Old Jan 24, 2008 | 09:21 AM
jakehendrix's Avatar
chirping
i have a 99 f-150 ext cab,4.6....i have something like a chirping sound when the truck is at an idle.sometimes it gets faster when i rev it up.it doesn't do it all the time...i thought it might be a pulley or something but i can't seem to tell where the noise is coming from.....anybody else ever had this mysterious chirp....thanks
Old Jan 24, 2008 | 09:23 AM
mrpositraction's Avatar
It is a pulley. If it is increasing with rpms. Most likely an idler. If you pull the belt off you should be able to see if there is any free play in any of them.
Old Jan 24, 2008 | 10:11 AM
RacingJake's Avatar
I've had bird's make a nest in one of my exhaust pipe's and even around the engine. Rat's too, knew a guy that had a cat in the fan shroud.
Open the hood and let it out
Start with removing the belt then start the engine to see if the noise goes away. Stop the engine and turn each pulley to see if it makes a noise.
Most likely it the air compressor clutch if you have AC and the compressor could be on it's 9th live.
Old Jan 24, 2008 | 10:15 AM
phil6608's Avatar
Iv had the belt make that noise too.
A Gator-back belt fixed it!
Phil
Old Jan 24, 2008 | 10:58 AM
NYfordguy's Avatar
Check your harmonic balancer (crankshaft pulley) the rubber ring on mine deteriorated causing a terrible squeak and eventually it flew off one cold morning!
Old Jan 24, 2008 | 02:51 PM
TECHDOC's Avatar
Ouch!
Old Mar 29, 2008 | 11:48 AM
kasparsport's Avatar
Jakehendrix, did you ever find the problem with the noise because mine is doing the same exact thing. I had the serpintine belt changed but it still makes the noise, not as bad though.
