Are these any good?
Old Jan 20, 2008 | 02:03 PM
4.2trimble's Avatar
Exclamation Are these any good?
http://www.stylintrucks.com/parts.as...&partid=472976
ok im replacing my spark plug wires will these do the trick? it is specified for my truck 97-03 F150 4.2L... so i figured they were good any opinions will help and any info will help out on Taylor that is the brand.
Old Jan 20, 2008 | 02:21 PM
4.2trimble's Avatar
any help?
Old Jan 20, 2008 | 02:30 PM
ONELOWF's Avatar
I don't know about those, but I like these.....a little pricey.
http://store.summitracing.com/partde...5&autoview=sku
Old Jan 20, 2008 | 11:20 PM
00Ford4X4's Avatar
As far as I know Taylor makes a good product. Looks like a good price to me...
Old Jan 21, 2008 | 01:16 AM
4.2trimble's Avatar
thanks alot guys!
Old Jan 21, 2008 | 01:53 AM
I would use OEM Motorcraft.
Old Jan 21, 2008 | 03:38 AM
4.2trimble's Avatar
im upgrading everything on the truck. any reason for you to say stick with OEM? the whole point is to clean up the engine bay, but if theres a reason not to se them please tell me! ive got nothing but good reviews
Old Jan 21, 2008 | 06:01 AM
phil6608's Avatar
You should be fine with thous weirs.
It's the aftermarket COPs that are over priced and junk!
But,,when it comes to pluge.Yes,,I would stick with OEM.A lot of guys having problems trying to run upgraded plugs.These trucks just don't run right with anything other then OEM plugs!
Phil
Old Jan 21, 2008 | 01:25 PM
Gotts2BMe's Avatar
Phil
my truck is doing pretty good on the NGK's it has....
Also if you are "upgrading" everything on the truck you should get something a little bigger than 8mm. 8mm is the stock size.
