squeeky belt
squeeky belt
i have a 95 with a 5.0, about a month ago the squeeking got unbearable so i replaced the belt, that solved my problem until today when i started my truck, it is a very quiet squeek but enough to annoy me, it gets louder when i tap the gas very lightly but when i rev it or am driving it doesnt squeek at all, not sure if this matters but the belt is oreilly's house brand
Use a good Gatorback belt next time....cheapo belts are known to squeak due to bad traction.
In the meantime, you can pick up a can of belt dressing. Start the motor, and just hold the spray over the belt and it runs along. The stuff dries and is really sticky, helps quiet squeals.
You may have a bad idler or tensioner pulley bearing as well.
Belt dressing is not a real good idea, if your belt is contaminated with oil or other foreign compounds, its trash anyway.
I do backup the idea of the abrasive application, toothpaste also works wonders and cleans up the pulleys with the micro abrasives and scratches the belt up good for traction on the pulleys, plus it washes off with water!
