engine start-up mystery-please help
Old Jan 15, 2008 | 04:15 PM
f150clay's Avatar
99' f150...problem at times starting engine with key...sometimes takes over 10-12 turns with key before ignition starts...any ideas on what could be the culprit...thanks
Old Jan 15, 2008 | 08:13 PM
F151's Avatar
Check for fuel pressure leak down at the rail..... Could be bad injector/s or pressure regulator.
On edit. Read your other post. It seems you may have issues with the ignition switch.......
Old Jan 15, 2008 | 10:27 PM
jethat's Avatar
Solenoid going out? That the first thing I'd check.. Cheap one is $10 at autozone..
