Whistle sound
Old Jan 2, 2008 | 08:16 PM
munoxide's Avatar
Whistle sound
I dont have any kind of intake mods on my truck, but when i floor the gas, when it gets to higher rpm, it starts making a whistling sound....anyone know what this is? Is something loose?
Old Jan 2, 2008 | 08:22 PM
Jughed's Avatar
Is it a used truck, someone might have removed your silencer. Need to put your truck details on there so people know what to tell you.
Old Jan 2, 2008 | 08:23 PM
munoxide's Avatar
Nah, bought it brand new....what details do you need?
Old Jan 2, 2008 | 08:28 PM
Jughed's Avatar
It is pretty important that people know what ya got in general. What year, motor, 4x4, what mods are done.
If it is a brand new 08 I would have no idea, but somone with a 08 might. Build a sig that way it is always there.
Old Jan 2, 2008 | 08:33 PM
RUSS04's Avatar
What year ? Motor ? Miles ?
Old Jan 2, 2008 | 08:41 PM
munoxide's Avatar
'01, 5.4,4x2,270k mi all stock.....anything else?
Old Jan 2, 2008 | 08:46 PM
RUSS04's Avatar
Sorry i cant help you I have a 2004 5.4 3v motor that does the same thing when it gets 0 degrees outside But it does go away when the truck warms up
Old Jan 2, 2008 | 08:52 PM
munoxide's Avatar
This does it after the truck is warm, as i always let it warm up to operating temp before i take off.
Old Jan 2, 2008 | 09:02 PM
twintips_17's Avatar
What servicing have you had done since it started. HOw long has it been doing it?
Old Jan 2, 2008 | 09:05 PM
munoxide's Avatar
I do regular maint. on it....but i havent really counted how many miles its been since it started, i know its been awhile now, but it only happens when you slam "pedal to the metal" kinda like air sucking in, but somewhere up towards the tb.....i dunno....doesnt happen on any other acceleration.
Old Jan 2, 2008 | 09:22 PM
RacingJake's Avatar
My 02 does the same thing and it's normal. Most likely just a large amount of CFM's going through a small hole or even the throttle plate may be causing it ??
When I hear it, that just tells me the motor is starting to find it's sweet spot and it's time to start passing everybody in sight
Old Jan 2, 2008 | 09:26 PM
Have you looked at your throttle plate, maf, or intake. How about making sure there is no leak into the intake by the throttle body.
Old Jan 2, 2008 | 09:31 PM
munoxide's Avatar
Havent checked the maf, and how can i tell if theres a leak into the intake by the tb?
Old Jan 2, 2008 | 09:36 PM
Listen for it while the hood is up. I found one by taking off the cover to the throttle body and listining as i manuely moved the throttle.
Old Jan 2, 2008 | 09:40 PM
munoxide's Avatar
Ok, thanks for the help. I think its getting worse with a possible leak after i pulled a circle burnout in the dirt the other day and after i stopped, the rpm's dropped way down almost to a stall.
