Buddies truck having problems
Old Dec 23, 2007 | 12:04 PM
krazyballer's Avatar
Well my friend has a 1990 f150 with a 5.0; he decided one day to do a compression check, so he finished put everything back together like is was ( or so he thought) went to start it back up it would crank but not fire. So after cranking her over for about 10 minutes it started to catch one cylinder at a time and black smoke was pouring out of the exhaust. So after idleing for a while tried to put in in drive it started to pop and died. Tried to start it back up and wouldn't then after another 5 minutes of cranking it started. It will idle as long as u want but as soon as u put a load on it will die. Any ideas Im clueless.
Old Dec 23, 2007 | 12:24 PM
Bluegrass's Avatar
Check out the MAP sensor vacuum line for being off or cracked open.
No map vacuum fuels the motor really heavey and fouls the plugs.
Usually a compression test is done with the throttle wide open. This causes no vacuum to the MAP and fuels to injectors heavey.
Next time, crank the motor with a shunt switch accross the starter solenoid and not use the ignition key. When you use the ignition key, the injectors fill the cylinders with gas.
On a motor already filled with gas, putting it all back togather and attempting to start, puts even more in on top of it = loooong crank times, run-down battery, overheated starter.
Sound like it's familuar?
Good luck.:santa:
Old Dec 23, 2007 | 06:00 PM
Yea ill have him check it
