What spark plus & trans fluid should I use?
Old Dec 14, 2007 | 10:23 PM
05'ThumpinSTX's Avatar
I'm changing my spark plugs and trans fluid this weekend and I just wanted to know if there are any high performance spark plugs instead of the generic Ford plugs that I should use. Also what type of high performance trans fluid should I use? 2005 F150 4.6L V8
Old Dec 14, 2007 | 11:43 PM
BLUE20004X4's Avatar
Save your dough for actual high performance stuff, plugs and tranny fluid do not show this. Motorcraft plugs are great, Denso too I believe. Start messing around with hotter plugs when adding blowers or nitrous, otherwise leave it. Tranny fluid? Anything Mercon V approved.
Ricers and queers like that believe in fluid horsepower and high performance spark plugs. I have Motorcraft regular 460 plugs in a 650 hp 514 ci engine, why would I need anything different, maybe it's a bit hotter spark than a stock 1975 460 originally had, I dunno.
The fact your changing these things is in itself the best performance it needs
Old Dec 15, 2007 | 12:20 AM
Stock Motorcraft platinum plugs or Denso Iridium and any Mercon V you want, full synthetic if you so desire.
Old Dec 15, 2007 | 10:40 AM
Galaxy's Avatar
Motorcraft Plugs and Amsoil fluids!!
Old Dec 15, 2007 | 11:52 AM
jbrew's Avatar
Yup!! ^^^ I agree..I can't beleive how much cooler my trans runs with Amsoil - It's worth the extra $$$ - AND , this trans has over 230,000 on it. Hits the gears without a pause.... I tuned the trans with hardware but still, the temp change blew my mind with Amsoil..
Old Dec 15, 2007 | 12:22 PM
Motocraft Platinum Plugs, and Amsoil Trans fluid it is! Thanks guys!
Old Dec 15, 2007 | 12:28 PM
Prego (you're welcome) thumpin man!!!
Old Dec 15, 2007 | 01:16 PM
If you do switch over to Amsoil fluid, I recommend you do a complete replacement, not just a pan drop, to get the full benefits.
