$1000 mods
Old Dec 9, 2007 | 07:42 PM
saxet666's Avatar
$1000 mods
ok, i have given myself about $1000 to spend on mods in the next couple of months. i'm thinking of a bbk throttle body, granatelli maf, hellwig sway bar and programmer?. what do ya'll think and what order should i purchase them in?
i'm basically trying to get a little more efficiency(performance, power, mpg etc.) out of this gutless "modular" thing fomoco passes off as an engine. currently i get around 15 mpg normally in a mix of city and highway driving, with an all time high of 16.5 mpg on pure highway driving. as far as speed, it has none, the k&n fipk i put on a month after i bought this truck has done nothing that i can tell for the gutless wonder.
any and all replies are appreciated, i just want to get some of ya'lls opinions, because this is still the best forum for f-series that i have found. i know i haven't posted very much, but i read a tremendous amount, and i can hardly discern what is good and what is bad.
Old Dec 9, 2007 | 07:55 PM
built54's Avatar
long tube headers and efans. thats 2-4mpg right that, plus a lot of power
Old Dec 9, 2007 | 08:09 PM
Casey05's Avatar
Call Mike Troyer and get a X2cal. Best thing I ever did for my truck. They can also help you get a custome tune with your fipk, maf and throttle body.
What motor do you have?
Old Dec 9, 2007 | 08:28 PM
saxet666's Avatar
$1000 mods
i have the 5.4 triton of course
what all does a custom tune involve? i'm a little fuzzy on how this works, as i am a true amateur.
thanks for the input.
Old Dec 9, 2007 | 08:47 PM
CDB03STX's Avatar
I would go with the Efans and programmer. Maybe xcal2 as mentioned. Definitely E-Fans: I'll Guarantee you will see a difference.
NYfordguy's Avatar
I'm with built, Efans, long tubes and a cold air intake.
Old Dec 9, 2007 | 09:04 PM
CDB03STX's Avatar
I disagree with the intake though I think he already has one. That's a waist IMHO.
Old Dec 9, 2007 | 09:05 PM
saxet666's Avatar
$1000 mods
thought about e-fans...still thinking about e-fans. i may do that in the future.
one other question. if i get the long tube headers, can i then run true dual exhaust and what kind of difference would that make?
Old Dec 9, 2007 | 09:18 PM
jbrew's Avatar
With a grand and a stock 99 .
AF1, A nice Cat Back and Tuner.. All from Troyer .
That's a nice start . Troyer can set you up with the perfect tune.
Those three combined, you'll get your moneys worth..
If you had 2 grand - Add.. Dynatech Headers and HF Magnaflows X pipe ..
3 grand - Add - Underdrive pullys - E-Fans..
I could keep going , but your already out of $$$
Old Dec 9, 2007 | 09:21 PM
jbrew's Avatar
You don't need true duals for power - headers alone = 30hp
Old Dec 9, 2007 | 09:25 PM
Gotts2BMe's Avatar
I did intake, efans, magnaflow 15749, and troyer tunes for <$1100
I even got gouged on the exhaust at $620
Old Dec 10, 2007 | 01:27 PM
CDB03STX's Avatar
If you had 2 grand .. Dynatech Headers and HF Magnaflows X pipe ..
3 grand - Underdrive pullys - E-Fans..
For 3 grand...you can charge it, efans, shift kit...I did Just got to shop around and do the installation yourself.
Old Dec 10, 2007 | 02:40 PM
kaptain's Avatar
If you open up the exhaust too much you will start to kill the power on these motors. They need a good amount of backpressure in the exhaust to make power, and even if you do manage to get a power gain, it will most likely add a little to the top end, and take some from the bottom end where its more useful. A good setup for exhaust would be a single out catback. A true double would make it too open.
kaptain's Avatar
Old Dec 10, 2007 | 06:21 PM
Casey05's Avatar
There is plenty of threads about this already, but if you go to the chips-tuners-and programmers section of this forum, you can read all about them. https://www.f150online.com/forums/chips-tuners-programming-34/
Here is Troyers website as well.
www.troyerperformance.com/
