Annoying whine????
Annoying whine????
i have a 2004 5.4l and its making and annoying whine which sounds like a supercharger and varies with rpms.. it sounds like its coming from the belt but its not that high pitched squel its more of a hum whine. it started when the temp started droping to around -10c. i gotta haul a load tommorow morning. should i be worried if my truck might break down... if there anything i could check or try...
i dont want to be stuck in the middle of the highway while the chevs and dodges r laughing at me
thanks
thanks
Originally Posted by jonamond
just reading around... could it be the water pump?
i have the same whine, seems to lessen as the truck warms up but is still there. mine can be heard more inside the cab cold or warm, which makes me think tranny. but ive only got 56k on the truck and the tranny fluid is very clean.
i do however hear some light grinding when rotating the steering wheel. i syphoned out the flyid in the resivor and added a bottle of lucas power steering treatment and it did quiet the noise greatly, though as the bottle worked its way through the sound slowly returned. I will be adding another bottle of lucas tomorrow ill let ya know how it turns out.
thanks
thanks
Now its starting to grind so i said "screw this im not gonna be Found On Road Dead" so i took it to a shop and they said its the tensioner pulley so thier fixing it now.... we'll see what happens
Ive got the howling whining problem too, funny thing is i just bought an alternator from autozone about 3 weeks ago around the time the noise started. What did you do, take yours back and buy a diff one?
Mine does that too, a barely audible, rapid "squeaksqueaksqueak" that varies with RPM. If I spray the tensioner with WD40 it stops for a couple minutes, then comes back. I can barely hear it, and it hasn't gotten worse for months so it's not a pressing problem. Though my motor is getting on 15 years old.
