2004 4.6 motor trouble
Old Dec 3, 2007 | 08:46 PM
VBTOY's Avatar
I have a 2004 4x4 f-150 with a 4.6 liter v8, it only has about 26k on the motor, I was recently on the highway and the check engine light flashed, then went off then came back on later. ONce I pulled off the highway the truck was running very rough...looked in owners manual and it stated flashing check engine light is indication of misfire. I took it to advance and codes read misfires in 4 cylinders and a too lean code. Took it to a dealer cause it started knocking some...he pulled no 3 & 4 Cylinder plugs and the tips were burnt off. He ran compression check on both cylinders and got 17% and 24% respectfully. The truck is four months out of warranty. I got a couple questions:
1. Anyone ever heard of this happening and if so can you provide some info?
2. Do you think Ford will do anything for me?
3. Truck has K&N Cold Air intake on it, do you think that could have effected it or cause issues with Ford?
Thanks for you Time!!
Old Dec 3, 2007 | 08:56 PM
Faster150's Avatar
wow musta gona really lean! probably damaged or cracked a piston? did u hear any detonation?
Old Dec 3, 2007 | 09:08 PM
VBTOY's Avatar
What would it sound like? made no beig noises or anything....
Old Dec 4, 2007 | 09:32 AM
Poter's Avatar
you should of put the stock intake on before taking to the dealer... I think they aren't going to help you out on this one cause of the aftermarket intake, but good luck, and keep us posted
