e-fan wiring question
Old Dec 3, 2007 | 10:03 AM
krakakru21's Avatar
i have a 99 f150 4.6. i just installed the flex a lite e-fan kit and it is awesome. my question is when hooking up the wire(s) for the a/c do i need to hook up just the power to terminal 8 or do i need to hook up the ground also and put it in terminal 7. the fan system is already grounded so i was not sure if i needed to ground it again. the power wire from the a/c is the grey/white stripe wire and the ground is the black wire coming from the plug. someone shed some light on this please
Old Dec 3, 2007 | 10:19 AM
JMC's Avatar
JMC
25 Year Member
The instructions say to connect one or the other. As the A/C is grounded by being connected to the engine you need to use the positive lead. That would then need to be connected to terminal #8. Page 2 of the instructions para 4.
JMC
Old Dec 4, 2007 | 08:19 AM
waterman308's Avatar
The FAL controller is just "listening" for a 12v signal when you splice into the grey/white wire from the compressor. That trips the relay to start the fans when the AC comes on.
Old Dec 5, 2007 | 09:17 AM
krakakru21's Avatar
ok thanks for the help, i will only hook up terminal 8
