evolution prolems
Old Nov 27, 2007 | 09:09 PM
ronniec24's Avatar
evolution prolems
after running my edge on extreme a week or so the performance on my truck degrades. when im in extreme i make sure i use 93 only and ushally is the second tank so i know its clean 93 not mixed any with 89. when running below 2500 my truck will sometimes miss also it runs alittle rich. when i put it back to stock all seems fine. is this a common problem?
Old Nov 27, 2007 | 09:58 PM
wreedKR's Avatar
we need some info on your truck.
Old Nov 27, 2007 | 10:13 PM
ronniec24's Avatar
2005 f150 screw FX4 5.4 52k miles 40 series flowmasters
Old Nov 27, 2007 | 11:05 PM
Are you bumping your timing at least +1.0? Have not heard of the problem you are having.
Old Nov 27, 2007 | 11:06 PM
wreedKR's Avatar
shouldnt running the stock edge programs be OK and prevent running rich, lean , etc?
Old Nov 27, 2007 | 11:09 PM
By extreme, are you referring to Level 3? What custom settings are you doing?
Old Nov 28, 2007 | 06:16 AM
ronniec24's Avatar
edge
yes i mean level 3, not a custom program when you floor it you can see some smoke and i have a litle soot on my tips of the exhaust. when i go back to stock everything is fine. when in extreme mode it just does not run well unless you keep the rpms above 2500 or so.
Old Nov 28, 2007 | 07:00 PM
Faster150's Avatar
evolution problems?? only if ur from alabama where the gene pool is shallow j/k
