POS thermo controller.....
Old Nov 19, 2007 | 07:25 PM
seidita84t's Avatar
Exclamation POS thermo controller.....
well, i've had my troyer fans for about 2 months now, and they've been great... till the other day when i noticed that the fans still ran well after the ignition had been turned off. well it stopped, i do alot of highway driving so never really noticed a temperature increase... i did notice that when stopped that the a/c would cycle on and off. and that when i turned on the a/c, my high side fan would not turn on, i checked my connections, to realize that BOTH of them are completly melted under the relay, and the relay's are thrashed?????? this sucks.....
Old Nov 19, 2007 | 08:05 PM
Bluegrass's Avatar
Without seeing how the install was done, you need to be sure all connections especially any push-on are the best available and all type connection have zero resistance.
Reason is if there is any substantial resistance at the connection, it runs hot.
A hot running connection corrodes and make it worse yet until the connection runs so hot it's temp get to the melting point of the surrounding material.
Example this; a connection with a resistance of 1 ohm trying to pass fan currents of say 30 amps will be equivelent to 900 watts at an area that will never handle this power/temp for very long. How the example is figured is with electrical law of current squared, divided by the resistance or (30 x 30) / 1 = 900 watts of power when is should be less than about 5 or 10 at most.
This is what makes anything melt that normally does not run hot.
Old Nov 20, 2007 | 01:56 AM
seidita84t's Avatar
i used only the stuff troyer sent me, they gave me a whole box full of goodies...
