i hate my truck now
Old Nov 18, 2007 | 06:28 PM
corey v's Avatar
i hate my truck now
ok i have changed my plugs, the boots and springs on the coils and my truck still has bad hesition when i going down the road, around 30 60 its reall bad but i dont know what to do iam frustratedits a 2001 4.6
Old Nov 18, 2007 | 06:31 PM
built54's Avatar
around 30 or 60 just cruising or acclerating? you change the fuel filter or clean the MAF?
Old Nov 18, 2007 | 06:34 PM
corey v's Avatar
it does when iam doing both yeah i changed the fuel filter but didnt clean the maf
Old Nov 18, 2007 | 07:15 PM
shifty_85's Avatar
what kind of plugs?
Old Nov 18, 2007 | 08:33 PM
krazyballer's Avatar
When u say u replaced the boots im guessing u mean u replaced the plug wires make sure u routed the wires right.
Old Nov 18, 2007 | 08:45 PM
2001 should be COP. Replace the whole COP, not just the boot. 96 bucks shipped for a full set from Global on eBay.
Old Nov 18, 2007 | 08:48 PM
My bad
Old Nov 18, 2007 | 09:09 PM
wde3477's Avatar
Are there any codes - does the 'check engine' light come on?
Old Nov 18, 2007 | 09:19 PM
Gotts2BMe's Avatar
how many miles you got on there. have you ever changed the pcv valve
Old Nov 18, 2007 | 09:28 PM
jbrew's Avatar
That's got my vote. ^^^^^^
BUT - He could have the wrong plugs in there - answer "shifty 85's" question corey, just to make sure..
Old Nov 18, 2007 | 10:01 PM
corey v's Avatar
yeah i reaplaced them with ngk plugs iridium, ok if it one of the cops then i do i know wich one its is, yeah i replaced the boot and spring on the cops it has a little ove 105 thousands miles and no it not showing a check engine code, my friends think it the programer i out on my truck but i dont think its that
Old Nov 18, 2007 | 10:11 PM
Bvette85's Avatar
If you think it is a bad tune from the programer, try returning to stock and see if it still has the problem.
What programer do you have?
Old Nov 18, 2007 | 10:14 PM
Adam06FX4's Avatar
Registered User
just because your check engine light isnt on doesnt mean there isnt a pending code. without scanning your truck all your doing is guessing.
Old Nov 18, 2007 | 10:23 PM
shifty_85's Avatar
i dont have COP's but when my truck mis fired under a load it didnt throw a misfire code bc it was fireing just at like 1/4 spark so the computer thought everything was fine. but when i mentiond the plugs i had in my truck the guy at autozone said it was the plugs *i had bosch plugs someone at murrys talked me into geting them* but i replaced the bad plugs after only 10,000 miles with autolites and no more probs!! but NGK is good plug so i dont think its that
Old Nov 18, 2007 | 10:25 PM
corey v's Avatar
i already checked it on my programer its the super max micro tuner it was doing it before i put the program on there and i checked it the dtc ready on it and there are no trouble codes
