heads ??????????
Old Nov 15, 2007 | 12:26 PM
ssj4shane's Avatar
heads ??????????
What can you do to the heads to get more power
porting
cam ??
navi heads ??
other people make them??
what power could i see ??
i have a 2000 5.4 motor
I cant look this up no more because i cant find someone who asked this question
Old Nov 15, 2007 | 09:43 PM
BLUE20004X4's Avatar
Kinda poke around the lightning section, try www.teamjdm.com for stuff. Patriot performance has heads in stages I think. I'm kinda kickin the idea around too so I've paid attention as much as I can when I see articles. Magazines having alot of Lightning content have ads for stuff like this but I swear I've read here a whole bunch and different places to get parts.
Old Nov 15, 2007 | 10:18 PM
phil6608's Avatar
Don't forget JLP and LFP . Both great places to get parts.
I have stage 2 Patriot heads and cams in my truck.
Phil
Old Nov 15, 2007 | 10:44 PM
crash_lucky13's Avatar
i have a motor i'm building on the side. best bet would be to grab up a set at a junkyard and work on them in your spare time...
also got stage II comp cams, lifters, etc
Old Nov 16, 2007 | 12:43 AM
ssj4shane's Avatar
like could i just buy navi heads and put them on like i want more power lol
Old Nov 16, 2007 | 07:51 AM
yes and no. the navi heads are the ones with more valves correct?
get em ported and polished then throw them on there
Old Nov 16, 2007 | 08:10 AM
ONELOWF's Avatar
http://www.foxlakeracing.com/mod2.php
Old Nov 16, 2007 | 09:52 AM
RacingJake's Avatar
Here's my 2 cents
Just head's alone you may not see/feel much differents in power due to it's just one part of the puzzle. It's the total package that get's you more HP, like heads, cams, exhaust, gearing, tuning, etc. If you're not a WOT type of guy then you may never feel the extra ponies. Plus add the weigh of a truck and that robs HP too.
Another thing to know is flow rates, you'll see some nice numbers but they are at max lift normally, I like to have a valve train that will last a long time so that means smaller cams for me.
The only one mod that will give you a real kick in the pant's is nitrous but you need to know how to tune it.
I always like to start out with a gear change first cause it's simple and you can feel the torque plus it's dictate's the rpm band, like when you going down the freeway.
What ever you do Good Luck
Old Nov 16, 2007 | 09:56 AM
KEITHHATTER's Avatar
I vote gear change first.
Old Nov 16, 2007 | 10:36 AM
Veteran: Army
there's alot more than just buying a set of navi heads and bolting them onto a 2 valve 5.4 engine
you'll need pistons (so an engien rebuild)
an intake manifold that will fit the NAVI heads (either a stock navi intake or an aftermarket one)
throttle and cruise control cables
front engine cover
AND you'll lose low end torque with the navi heads (unless you are boosting it)
Old Nov 16, 2007 | 11:45 AM
Grab Some 4.10's, You'll Love Them!!
Old Nov 16, 2007 | 05:46 PM
ssj4shane's Avatar
from the looks of it im just going to turbo or do the L swap
i have gears and troyer tunes and intake and performance coils and wires
plus elctric fans and highflow cats and what not.. I got little things
yes i have wires I did a 4.6 to 5.4 swap...
i was just woundering what i could do for heads...
because 4v would be nice
Old Nov 17, 2007 | 05:32 PM
Veteran: Army
the navigator heads are nice and they perform even better under boost but there is a bit of work involved in the swap. PM me if you want more info on the swap
Old Nov 18, 2007 | 01:10 AM
built54's Avatar
i'm happy with my engine swap. build a blower engine!
