best spark plug?
Old Nov 14, 2007 | 10:49 PM
polpilot's Avatar
best spark plug?
what is the best spark plug out there and whats the idel gap to run for 2001 f150 4.6 w/ edge runnin 91 octane. mods in sig
Old Nov 14, 2007 | 10:52 PM
MGDfan's Avatar
The best cost no object = Denso Iridium
The best with cost in mind = Motorcraft.
Gap is 0.05x
Old Nov 15, 2007 | 01:29 AM
polpilot's Avatar
Gap is 0.05x
What about the denso Double platinum? there have the price of the Iridium
Old Nov 15, 2007 | 12:00 PM
If the choice is between platinum and iridium, I'd take iridium.
Note that the plugs Troyer sells are the Denso Iridiums.
Old Nov 15, 2007 | 12:24 PM
MmmBuckles's Avatar
ya. if i was you i'd just stick with the motorcraft. i had those platinums before and 3 of them blew. they were crap
Old Nov 15, 2007 | 01:16 PM
mustangraven's Avatar
sorry but good old copper plugs work the best they are inexpensive and these great super cunductive snake oil plugs out there especially the ones with mitliple paths for spark are a joke. they will work until a little carbon builds wich will be about 5 minutes then they electricity will do what it always does find the path of least resistance and give spark there. hence good old copper! just my .02
Old Nov 15, 2007 | 01:20 PM
Norm's Avatar
The stock plugs are platinum.
Old Nov 15, 2007 | 02:05 PM
Copper plugs are not recommended for the Ford OHC mod motors and OHV 4.2 V6's. Run them all you want in the old 4.9 I6 and 5.0/5.8/7.4 OHV V8's, those do work best in those engines.
Old Nov 15, 2007 | 02:51 PM
Quintin's Avatar
Motorcrafts at .052-.056" gap.
Old Nov 15, 2007 | 09:56 PM
Octane36's Avatar
The best plugs for your motor are either Motorcraft or Autolite. You cant run just any old sparkplug in your motor, you need plugs that are designed for DIS (distribtorless ignition systems).
If you use some cheap copper plugs, it wont run right.
Old Nov 15, 2007 | 10:02 PM
gixxer's Avatar
Ngk
Old Nov 15, 2007 | 10:07 PM
shifty_85's Avatar
Autolite Double plat!
Old Nov 16, 2007 | 09:28 AM
KEITHHATTER's Avatar
MOTORCRAFT
Old Nov 16, 2007 | 04:07 PM
97_4sixer's Avatar
Motorcraft
