engine dies at idle
Old Nov 12, 2007 | 12:49 AM
full_tilt's Avatar
engine dies at idle
HI
1999 Ford F-150... 84K miles
just started tonight engine will not idle... it dies
my fuel filter is overdue for a change... could this be the culprit
what else could be causing this
Old Nov 12, 2007 | 02:38 AM
redjet's Avatar
try cleaning the Idle Air Controller
Old Nov 12, 2007 | 07:38 AM
Tumba's Avatar
change the filter also, it needs it.
Old Nov 13, 2007 | 02:37 AM
full_tilt's Avatar
thanks a lot for suggestions & responses
changed fuel filter tonight - had only been changed once before for all 84K miles in this trucks lifespan (about 40K miles ago)
judging by a 15 min test drive the problem is fixed... engine sounds & runs much better
the engine failing to stay running was an intermittent and short lived problem for past two weeks. last night it appeared that it was there to stay
Old Nov 13, 2007 | 07:41 AM
Tumba's Avatar
it may not be fixed yet. just improved so it can operate better
Do some searches and other maintanance procedures.
if you run into a problem you don't understand just post it in this thread and someone will help.
Old Nov 14, 2007 | 12:47 AM
full_tilt's Avatar
you're right Tumba... not fixed yet
so far have replaced fuel filter and cleaned MAF valve
tonight tried to start start truck... it fires up then dies right away... only way to keep it running is to apply gas to keep RPM's up above 600.... as soon as I let off gas pedal the RPM's fall so low the engine dies
so it seems to be an intermittent problem and has gotten worse in the past couple of weeks... only time it has happened so far is at night when the temperature drops and when there seems to be more moisture in the air
does this sound like it could be the idle air control valve - will clean this tomorrow - what else could it be
thanks
Old Nov 14, 2007 | 01:53 AM
IAC is the next step.
Old Nov 14, 2007 | 02:14 AM
jbrew's Avatar
Yup! these trucks will idle @ 600 RPM , you just can't here it running when it does - I'm serious - been there when I forgot to take a temp vac plug off and it got sucked into the IAC .. Anyway if she won't idle above 600 RPM it's definitely a stuck IAC.
When you clean , its best if you have compressed air to assist. You can force WD40 in areas needed to free it up. WD40 will not hurt the IAC , but harsher chemicals can. After you spray the lubricant/cleaner ( Deep Creep made by SeaFoam is best - that stuff lubes and cleans at the same time) your going to have to work the mechanical's with a screwdriver or a small pair of needle nose pliers to loosen her up good..
Good Luck
Old Nov 14, 2007 | 03:23 AM
full_tilt's Avatar
thanks for suggestions!
will tackle IAC tomorrow
