4th radiator
Old Nov 1, 2007 | 07:55 PM
98 Blues's Avatar
Unhappy 4th radiator
I have replaced 4 radiators in 4 years. I was told it could be "electrolysis" in the cooling system coming from a bad ground in the starter. I did the test, and sure enough the test indicated the starter was the cause.
Just wondered if anyone else has seen this.
Old Nov 1, 2007 | 11:02 PM
Adam06FX4's Avatar
Registered User
grab a voltmeter. set it to DC. put one probe to the negative terminal on the battery and dip the other one in your coolant reserve. tell me what you get. should not be over 0.5 of a volt.
Old Nov 2, 2007 | 07:56 AM
BlueFlareside's Avatar
You would get more answers if you posted this in the "Electrical" or "Engine" forums. The "Comments & Suggestions" forum is for comments and suggestions concerning this site not your truck.
Old Dec 1, 2007 | 12:29 AM
twilloughby's Avatar
radiator replacement
Where is yours leaking? Have you found a replacement that lasts? Have you found the problem?
Any help is appreciated. I am going on my 4th.
Old Dec 1, 2007 | 03:44 PM
Bluegrass's Avatar
Might be the water used to fill the system.
Won't go wrong for the small cost of getting it in jugs from the store.
My home water is ph acid and does a good amount of eating the plumbing over about 5 years time.
Old Dec 1, 2007 | 03:59 PM
Tumba's Avatar
has anyone else heard of this.
i know on some old tractors the radiator had to be grounded for the same reason.
i'm sure it is a ground problem somewhere
