squeaking and chirping
Old Oct 25, 2007 | 04:31 AM
Tanner_F150's Avatar
Hey guys
So, I have a 2000 F150 extended cab with a 4.6 L 4x4.
I have a chirpin noise that seems to come around 1400rpm. it increases in frequency with my THROTTLE, not with the rpm. i.e. if i hold down my brake and hit the gas, the frequency of the chirping increases at a faster rate than my rpm does. Oh, and for a final head-scratcher, it stops doing it if i kick it into neutral.
to me, this means its not a drivetrain issue to do with wheel bearings or anything that is moving, rotating, etc.
Anyways, I'm out of ideas. How about you guys, any clues??
Thanks,
Tanner
Old Oct 25, 2007 | 06:47 AM
torkum's Avatar
The first thing I would do for the noise you have described is take the serp belt off and run the engine without it for a few seconds to see if the noise goes away. If it does go away check the pulleys for loose or extra bearing play.
