Oil pressure problems when its cold
So I have been noticing in the mornings, that when my truck is cold, and I first start it, the oil warning light is on immediatly. And then when my truck gets warm, the oil light goes away, and the gauge moves to normal and everything is fine.
Is this something that anyone has ever seen before? Is this an issue I need to worry about swapping out the oil pump? What are yalls thoughts on this ?
Please Help ????
i am having the same problem. mine is 4.6l crew cab 4x4 with 105,000 on it.
i'm having the same isue when its cold?\ is it something to worry about?
the gauge is up and down when its cold and oil light comes on, when it warms , normal operating temp on gauge. please help!!!
I found this now that I know it could be the oil position switch.
hat is the information from Autozone's website. I am going to get it and install it Sunday or Monday. Will reply if it fixes it. This is for the 5.4l
Duralast / Oil Pressure Switch PS407
anyone know the location of the oil pressure switch?
Originally Posted by Pheonixx
what weight oil are you using? perhaps that tired oil pump cant handle 10w30 anymore?
It's only supposed to take 4-6 psi of oil pressure to make them. It's pretty rare for the oil pump to actually fail from wear or age.
Steve
went to ford saturday.
they told me to change my oil from 5 w 30 to 5 w 20w syth blend.
ford recommends all there engines run this oil. light less restrictive.
and they sold me a $12.00 piece oil sending unit.
he said that'll fix it. its located right close to oil filter on my model. thanks guys
