cop problems??
Originally Posted by jbrew
It would be missing within the rpm range - not running from low to high rpms..
You might be better off going thru the whole thing - suck test the EGR VALVE. Make sure it isn't stuck , only takes a second . Pull the vac hose off the EGR and install a seperate hose and suck on it like your drinking a milkshake while its running. If theres deflection in the way it idles , your fine . If nothing happends , the EGR is faulty.
the egr valve is the round ufo looking piece with one vacuum plug in it right??
