5.4 2007 f-150 fx2 sounds like a diesel
Old Sep 21, 2007 | 02:40 AM
trim1988's Avatar
Exclamation 5.4 2007 f-150 fx2 sounds like a diesel
I had about three months ago went out and got a 2007 fx2 f-150 crewcab with 21 miles on it. I notice a funny noise when i would start the motor. Then around about 1500 miles i notice that there was a knocking noise that sounded like a harmonic balancer had went bad. So i took it in and they said there was nothing wrong with that noise. Then around about 2000 miles i was backing in to a parking spot and my truck died. Then later that day i was at a stop light and my truck started to shack like crazy. i took it in again but this time to a local dealer and they said that there was a service bulletin were there is a spacer that was left out of the crank shaft which was causing this problem. They also said that 1 out of every 100 motors made for the 2007 f-150 have this problem. So if you have these make them check this. Since they kind of have to. Also has anyone heard of this before.
Old Sep 21, 2007 | 07:43 PM
chris1450's Avatar
Do a search... you are probly one of the lucky ones who is getting a new motor. It is a bummer.. but it hapens now and then. There are several threads about low mile 5.4's crank problems.
Old Sep 21, 2007 | 08:13 PM
FordScrew24's's Avatar
Mine happened at 580. But, mine also included digging into the tranny and replacing the computer. Needless to say they did a Buyback on it, and now i have 4500 on the new truck with no problems so far. Good luck with yours.
Old Sep 21, 2007 | 08:44 PM
swank07''s Avatar
So..... I am at 12k I haven't been notified and haven't noticed any odd noises, should I call it good? If I was to have a failure like this it should have happened by now?
Sorry to hijack thread
Old Sep 22, 2007 | 04:31 AM
trim1988's Avatar
If you have 12k on your motor you should be fine. BUt if not you still have a lot or warranty on your motor. BUt if it dies on you and shacks bad take it in asap don't wait at all.
Old Sep 22, 2007 | 12:23 PM
swank07''s Avatar
Roger that
