04 engine noise
Old Sep 18, 2007 | 10:14 PM
rhenson1's Avatar
04 engine noise
Newbie here with a question that has probably been answered alot but after some searching I havent seen it. My 04 5.6 3v sounds like a diesel at idle. I went to trade it in today and the owner of the car lot told me he didnt want it because of this. He said it is the cam guides or something like that and it will eventually be terminal. Can someone tell me if he is right or full of it. I have noticed the ticking but just thought it was a quirk of the engine. Thanks Ron
Old Sep 18, 2007 | 10:34 PM
cdnance's Avatar
he is full of it. it is something like the cam timing phaser, or cam phaser or somthing lke that. but other than just being somewhat annoying it wont harm anything. they changed it mid 05 i think. and i am also assuming you are talking about the 5.4
Old Sep 18, 2007 | 11:17 PM
hllon4whls's Avatar
Do a search on cam phaser.
Dont know if it could damage anything. Realistically must be done by a mechanic.
Old Sep 19, 2007 | 10:46 AM
rhenson1's Avatar
Yes i meant 5.4. Thanks for the input. I will search for cam phaser
Old Sep 20, 2007 | 12:27 AM
04ScrewFX4X4's Avatar
I am having this same problem any other info would be much appreciated not having much luck. Going to take it in, powertrain still under warranty. I have two problems, one is what I now believe to be the clutch on fan, and this I have this ticking sounds like a lifter?? or something of that nature. 04 Super Crew with 40K 5.4
Old Sep 20, 2007 | 01:22 PM
jbrown226's Avatar
I'm having this same issue, too. I just bought an '04 F150 Lariat Scab 5.4 Triton V8, and it sounds almost like a diesel. I didn't know if this was just typical, because this is the first Ford truck I've ever owned (always had Chevys before). I'll have to check into that cam phaser & see if what I can find out.
If anyone else has had this problem or knows what it might be, any info. would be greatly appreciated!
Old Oct 3, 2007 | 12:02 AM
jonamond's Avatar
i got mine checked at a ford dealer and they said it is the new design of the 3v and its normal
Old Oct 3, 2007 | 12:14 AM
Zepplin27's Avatar
Post Fact or Fiction
Ive just stared a thread about starting my truck sounding like that!! However, ford states that its the oil filter i use not having a Anti drain back which prevents the oil filling up in the filter.. Although after everyones insight about this issue, Im thinking who ever told me that at Ford was full of @#$@.. After my truck warm up like two seconds its fine, however it sounds like its about to turn into a Diesel!!
Old Oct 3, 2007 | 12:57 AM
What oil filter are you using? The dealer may be telling you the truth. Stick a Motorcraft in it along with the recommended 5W20 and if it still does it, then you have a case.
