Question about possible blown head gasket
Old Sep 17, 2007 | 10:12 PM
Turboduane's Avatar
If you replace the head gaskets I would also replace the 4 freeze plugs under the front timing cover. i had one leak at 90K miles and fill the oil pan but not a drop outside. They are only about 1.50 each but it cost me ~950 yo replace them.
I've got a nephew with a possible blown head gasket. 1997 4.6 w/ 100,000 miles.
He said he noticed it getting hot, pulled over and found the radiator low. Filled it and drove on. Nextday it got hot again, again no water, checked the oil and its milky.
It looks like I'm going to help him repair this truck, and he's on a very tight budget. However, I found the above quote, and started wondering if the freeze plugs could be the problem, instead of a head gasket? What are the odds?
Looks like a lot of you are replacing the heads and leaving the engine in the truck. Is that the easiest way?
Thanks in advance.
TD
Old Sep 17, 2007 | 10:21 PM
torkum's Avatar
This is the way to go if you have a lift:
Old Sep 17, 2007 | 10:43 PM
Okieboy's Avatar
Scroll down
Old Sep 17, 2007 | 10:46 PM
Okieboy's Avatar
Thanks in advance.
TD
Head gasket, Cracked block or cracked head and (or) leaking or cracked intake manifold leaking throught the lifter valley right into the oil pan. Usually one of the four. Inspect every part as you disassemble! Freeeze plugs will not cause water in the oil. But it may be a good idea if your working around the area because if the person that owns the vehicle is not performing scheduled maintenance on the vehicle this will probally enlighten you on the condition of the freeze plug. Most plugs will show signs of erosion by a rust color or a trace leak look. You make your call because most are difficult for the average person to replace.
Old Sep 26, 2007 | 12:15 AM
Turboduane's Avatar
Cute, I don't think thats going to be the way to go.
