Temp Gauge Range
Old Sep 10, 2007 | 07:13 PM
mig25's Avatar
Question Temp Gauge Range
My F150 Temp gauge goes up about 1/4 when driving. Is this a normal range?
I have flushed my cooling system and replaced My thermostat, stock temp range .
Here is a picture of my engine fully warmed up , idling :
Old Sep 10, 2007 | 07:17 PM
JD's150's Avatar
It looks right to me. Thats right about where my gauge sits when its warmed up.
Old Sep 10, 2007 | 07:25 PM
built54's Avatar
100% normal, mine has never went higher than that except for 1 time... right b4 the red, and I logged it, it was at 250*... I put a new water pump in it and a lower thermostat, and flushed the coolant. No more overheating.
Old Sep 11, 2007 | 12:49 PM
Steve83's Avatar
Old Sep 11, 2007 | 03:50 PM
Care to translate that into something us ordinary people can understand and relate to, Steve?
Old Sep 11, 2007 | 03:55 PM
Quintin's Avatar
Looks about right to me. Those gauges only know "cold," "operating temp," and "overheat."
Old Sep 12, 2007 | 11:09 AM
Steve83's Avatar
It's pretty straightforward. If you can operate a voltmeter & a thermometer, you can test your ECT to find out if it's giving the proper signal to the EEC & gauge.
Quintin
No, it's full-range analog sender & gauge system. Only the oil pressure is a fake.
Old Sep 12, 2007 | 11:37 AM
Steve, when did they switch over to the fake temp gauge? I think I understand that my 03 is a fake and actually works off cylinder head temp, not coolant temp.
Old Sep 12, 2007 | 12:06 PM
ONELOWF's Avatar
This is what it looks like to me. 97-98 have separate ect's for the pcm and dash gauge. My dash guage shows a steady climb during cold start warm up and the needle stops at the exact spot shown in the photo, and stays there. I also have an Auotometer gauge which tells me the spot where the dash needle stops is around 170*. The Auto meter continues to climb to 205* after the oem has stopped moving.
I know the oem works at a higher temp range, as I forgot to put the fuses back in for the efans once and it climbed.:o
Old Sep 12, 2007 | 12:32 PM
SMIGGS's Avatar
It would also vary on the thermostat in the truck. Both my 5.4's show right in the middle. And I believe they have a 190 thermostat from the factory.
Old Sep 13, 2007 | 06:17 PM
Steve83's Avatar
NEVER.
...my 03 is a fake and actually works off cylinder head temp, not coolant temp.
That's not fake - it's actually showing the real temperature of the engine, which is what you really want to know. It's just using a new type of sensor that's dry.
Your truck's PCM probably isn't the switching type described in those diagrams, and you can still test the CHT output with a common voltmeter.
