K&N FIPK Intake Kits
Originally Posted by chester8420
It does NOT help anything at part throttle. Think about it... If you maintain a steady ammount of throttle on an open road at 55mph, and you somehow pull the airfilter out, what will happen? The intake will have less restriction and the truck will speed up, right? And you'll have to let off the gas a little to maintain 55mph, right? What happens when you let off the gas? -- You close the throttle body, thus increasing intake restriction. So, did you gain anything by reducing restriction on the intake? NO!!!!!
If you need 200 hp at the wheels to get up to speed, and 50 gets sucked up by drivetrain/friction/pumping loses, then you need to produce 250 hp at the motor. Now my pumping loses drop by 2 hp due to lower intake restriction, so I now only need to produce 248 hp instead of 250 hp to achieve the same acceleration.
Done correctly, an aftermarket intake can help performace and fuel efficiency. In most cases it is a very small improvement but the operation of IC engines prove it works.
Greg
Originally Posted by Req
"I can go a steady 65 mph when my tac reads 300 rpms less than before.
The way to put it in the context of this discussion would be: "I can use xx% less throttle to maintain a steady-state 65 mph". A high octane tune will do that moreso than any intake change.
You, in effect, just confirmed that a less restrictive intake will allow the use of less throttle for equivalent speed. That's an efficiency improvement - and the best way to improve mileage is to use as little TP opening as possible, to maintain your desired speed.
Originally Posted by MGDfan
You, in, effect, just confirmed that an intake will allow the use of less throttle for equivalent speed. That's an efficiency improvement - and the best way to improve mileage is to use as little TP opening as possible.
As for the discussion here, if the driver has to let off the TP to maintain speed at 55 with the filter removed versus having to have more TP to maintain speed at 55 with the filter, then yes, you just have improved efficiency. One way to test might be to find a good exhaust cut-off but install it on the intake side with one inlet behind the filter and the other just free flowing and unfiltered, and with the MAF on the single outlet going into your intake tube. Hey, that might be a good mod! Make it out of lightweight plastic, exhaust cut-offs are metallic and heavy.
However, TP alone is not the whole input to the PCM for mpg. Knowing what your engine load sensor is saying also has bearing on efficiency. I know you can lighten up on TP, but if the engine load sensor goes up then it sort of offsets and mpg might actually go down depending on the balance. There are other factors as well.
Originally Posted by INFireRedF150
low TP but at a speed your tranny can at least be in OD. I see people here in town try to go even slower than I do for the sake of mpg. Slow speeds don't yield good mpg if the m part of mpg isnt high enough. Lotsa miles per very few gallons is the key.
Think about this for a bit;
If engine load requirements go up ( BTW - there is no Load sensor, Load is a calculated value), by necessity the TP% will go up as well , IF you try to maintain the same speed (as in going up a grade). And mileage goes in the toilet. TPS is one PCM input that detemines injector pulse width, and coupled with load (and a host of other things) also factors into how much ignition advance is appropriate.
Scangauge /Edge /Dashhawk /AutoTap /Xcal2 datalog will confirm this to be the case.
My example was @ stready-state cruise, relatively level, TC locked. Sorry if I wasn't clear.
bubba
bubba
bubbaYou were clear in your example. The word "maintain" was the key.
The PCM will increase TPS as the load goes up due to your foot doing nothing,
To my knowledge, in either an ETC ( see below) or normal mechanical throttled truck, the PCM cannot change it. Only your foot can. (Or your cruise contol actuator lol).
Actually, in an ETC, the PCM does contol the throttle electrically, but it's only in response to the TPS input to command a certain level of torque - it is still very much 'slaved' to your right foot, albeit a bit less directly.
Loose definition of Load = basically the amount of incoming air, ratioed against how much 1 cylinder can hold at standard pressure/density.
TPS is an input to the PCM, not an output from the PCM.
hmsa42
This would put be back to asking the vacumn cleaner salesman how great his product was. Thus, out comes the large steel *****. Asking a salesman how good his product is is like wrapping the noose around your neck.
I was not really looking for a test panel set of numbers to light my way. Something simple like "I gained 4 miles per gallon", or "I can go a steady 65 mph when my tac reads 300 rpms less than before.
Thanks gang for your help. I think I'll stick with the stock filter.
Is the cost savings over time worth it though? Especially if you plan on selling the truck in the next few years, who knows. For me it is, since I'm saving around +$700@$3/gal a year, and if gas prices go up, the savings go up as well. I also plan to keep the truck for as long as possible, so it works for me. I try to think of it as a performance enhancement that gives me a bonus of a little extra gas. I just don't think it'll give you the gains you are hoping it will though, 4 extra MPG and 300 less RPM's would be a dream purchase for me.
In the end, it's just trying the make the engine as efficient as possible.
I must not have a fully mechanical throttled truck, it seems my TPS can rise without my foot moving, weird to me.
You are using what to monitor this?
Bubba
BTW - I just realized this thread went into the weeds - sorry about the Hijack, OP! LOL!
On an '03? That is very wierd, as you certainly do have a directly attached mechanical throttle cable.
Bubba
Bubba
Scangauge II. Granted, if it seems to go up without me moving the pedal, it is minor, as if the cruise control was enabled and was adjusting the TPS, only not as much. I don't understand it fully either. If I was at 20 for TPS, and I went up a short grade, the TPS would go up to 21, 22, and maybe 23 yet I believe my foot didn't budge. Time to whip out the service manual dvd and see what is going on. I don't smoke or drink so cant blame that. Perhaps my PCM is doing to something to make it seem as if the throttle is being advanced if the TPS value is rising albeit slightly.
I have an ETC truck and mine does vary a miniscule amount if I hold it steady, but it's single percentage points, + or - .
bubba
Originally Posted by Gotts2BMe
Answer me this question....
You have a stock intake with a filter in it and you put it to EXACTLY half throttle and you accelerate for say a 1/4 mile. You then remove the filter and accerate at EXACTLY half throttle again for the same 1/4 mile distance which will get you there faster, with or without the filter?
So, if you accelerate 1/4 a mile with the pedal exactly half down, and then accelerate for 1/4 a mile with the pedal 6/10 down, then you've done the same thing. See your gas pedal controls air ONLY! The computer adds the corresponding ammount of gas. Give the engine more air, and it adds more gas. It doesn't matter if you do it with the "gas" pedal or with an air filter.
Originally Posted by renaud
I see your point, and it makes sense. But I was thinking more in terms of accelerating at part throttle not just maintaining speed. Getting up to 55 mph from 0 is alot harder on your motor, and that is where you use most of your gas. Upon acceleration the reduced pumping loses mean more power going to the wheels, which means less power overall that needs to be generated, which means less fuel burned (however small that amount may be)
Greg
Greg
Everybody is getting part throttle, and wide open throttle mixed up. It could help at wide open throttle, because your engine won't have as much intake restriction. But it CAN'T help at part throttle, because your engine is being choked by the throttle body!
A gasoline engine at part throttle is inneficient by design. You can't fix it by adding a low restriction air filter. Why do you think the 4.6 gets better fuel mileage? The main reason is that, you have to press the gas more to go the same speed as the 5.4, hence less intake restriction.
It doesn't matter where in the intake track the filter is. If I want 100 cfm of air in the engine, it will require more work from the engine (hp) to suck it through a dense filter than it would a free flowing one. Its fluid dynamics, you can't change that.
Well now...
Now, that is not practical at say 55mph. Because the engine would develop a lot of horsepower and take off. But if you could increase your gear ratio to a point where WOT would hold you steady at 55mph, then you would be at 100% efficiency with your intake, and a K&N would help. That's why a smaller engine in your truck will ALWAYS get better fuel economy. A 4.6L engine has to have the throttle body open MORE to maintain 55mph than a 5.4 does. A 4.2 (v6) has to have the throttle body open even MORE than the 4.6 at 55mph, so it gets better fuel efficiency, because of reduced intake restriction.
"fuel mileage wise" you are limited by the cubic inches of your engine, and the gear ratio of your rear axle. Those determine the ammount of air-per-time interval required to propel your truck 55mph. In theory, a 5.4 has the potential to be almost as efficient as a 4.2L. (it does produce more internal friction, but that is negligible compared to the "choking" effects of the throttle body)
Put it in context, your engine is a mass air engine. Meaning, if you give it more air, it burns more fuel. Idealy, an infinitely variable transmission would give you a situation where you would be driving down the road at 55mph with the engine at Wide Open Throttle at say 700rpm or so.... THAT would be a situation where you a large engine can nearly reach the efficiency of a smaller engine, and the air filter's restriction might start to come into play. But we don't have that with these "throttle bodied" engines.
The designers resort to choking the engine to regulate power output, rather than regulating RPM.
Now a diesel doesn't have a throttle body. It's power output is controled simply by the ammount of fuel you pour into it. But a gasoline has to maintain a constant air/fuel ratio, so you have to regulate the ammount of air it gets. And the fuel is injected in a set (more or less) ratio.
Conclusion... taking the air filter out would help "power output" at Wide Open Throttle, but it wouldn't help anything at part throttle, cause you could just stomp the "air pedal"
