cam phaser replacement...do it yourself?
Old Mar 18, 2009 | 02:55 AM
  #31
Iowa's Avatar
Originally Posted by blackf-150
Go to flatratetech.com and view episode #22 it goes completely step by step to change a cam phaser and lash adjusters and there are 2 special tools u will need it does not look like a DIY job though at home they have the engine on a stand and it is still a bit of work, FYI I have the extended warranty and still had to fight with ford to do the job, good luck
Great.....guess I'll just ignore it till it gets worse. I know thats a bad idea, but when your in college then your lucky to be driving that new of a truck anyway.
Old Jan 17, 2010 | 11:43 PM
  #32
jeffnort75's Avatar
Exelent site!! episode 22 clearly shows what to look for when it is about noises thanks for sharing your info.
Old Feb 1, 2010 | 08:38 PM
  #33
trx450er's Avatar
I did both of mine in under 2 hours not including the time to evacuate the ac and recharge it, but I evatuated it at work the day before I did it and recharged it the day after. I did alot of research on here before I didnt it and pretty simple.
Old Feb 1, 2010 | 08:52 PM
  #34
There is a great write up now, in our Articles and How To section.
Old Feb 3, 2010 | 10:25 AM
  #35
94yellow50's Avatar
so i just watched the article 22 just to learn a little more..idk if any of you guys noticed..but on the passenger side valve cover, where the line comes from the valve cover up to the throttlebody/air box, that line is missing lol..its just a open port coming out of the head. when they go to the close ups for the sounds coming from that head you can see it.
Old Mar 31, 2011 | 05:06 PM
  #36
amber car's Avatar
cam phaser torque specs
can anyone tell me the torque specs for the cam phasers on a 2005 ford f150 with a 5.4L??????
