coil help . . .
Old Aug 23, 2007 | 06:12 PM
dallas63's Avatar
coil help . . .
i have a 2000 ford 150 with 4.6 . i have replaced the coil on # 7 twice in the last three weeks and ses light on again saying misfire # 7 . i had the plugs changed in january . what else could be causing misfire on # 7 . any and all help appreciated . thanks jay
Old Aug 23, 2007 | 07:13 PM
jbrew's Avatar
Bad wires.
Old Aug 23, 2007 | 07:28 PM
torkum's Avatar
What kind of plugs are you running?
Old Aug 23, 2007 | 08:23 PM
Bluegrass's Avatar
You are talking code P0307 each time?
The coil, the plug, the fuel injector or there electrical connectors can all result in the same fault code.
Water or oil intrusion can also be a factor.
Unless this is all a coinisidence, which it could be, one of the other reasons is likely the real fault.
Never fail to at least remove the plug and look at it an inspect oyther parts involved.
P 0307 is a discription of total cylinder performance and does not sort out a specific part as the reason.
Old Aug 24, 2007 | 03:11 AM
jbrew's Avatar
Spark-Plugs ????
Old Feb 4, 2008 | 06:43 AM
dayalalito01's Avatar
Exclamation Was Po3o3 Now P0307 Misfire
Im getting the 0307 code , i recently changed the plugd never changed on the trco (97 expe 4.6), i was getting the 0303 code and teh engine was runing bad. RPM drop very low below 500 them jump back up to 700, CEL comes on and off blinking and steady on, soe one pleace help me what to change next,
Old Feb 4, 2008 | 10:23 AM
jbrew's Avatar
What's a "trco"?
What spark-plugs are installed ?
You check your wires ?
Old Feb 4, 2008 | 09:51 PM
typo its TRUCK, installed OEM motorcraft from dealer. gapped @ 52-56, i cant get to the last 2 plug on each side. any ideas
Old Feb 4, 2008 | 09:57 PM
motorcraft Platuim from dealer, JUST FIGUERED OUT I UNPLUGED THE #7 INJECTOR TO GET TO PLUG AND DIDNT PLUG IT BACK ! ALL GO NOW !!!
CEL IS OFF! AND RUNNIG GOOD !
