Heater Core
Old Sep 29, 2007 | 05:33 PM
joelmc's Avatar
I got er done, no problems with the backflush. Thanks Tumba. I also refilled the headlight fluid to the proper level while I was at it. :o)
Old Sep 29, 2007 | 06:35 PM
bricelittle's Avatar
headlight fluid??
Old Sep 29, 2007 | 06:40 PM
jbrew's Avatar
Must mean in between the ears - my best guess
Old Sep 29, 2007 | 09:34 PM
hahaha good one
Brice
Old Sep 30, 2007 | 11:59 PM
FF301's Avatar
I had to change my htr core last year, luck would have it a friend works on ambulances and knows how to take dash apart, while he worked dash, i worked under hood installed new hose's on both core and rad flushed everything lost some dash lights but it only took us about 4 hrs
heater cores usally leak into cab, if it's leaking under hood it mght only need new hose's since the seal might be all thats leaking
Old Oct 1, 2007 | 12:03 AM
KYFXF's Avatar
Had to do mine last fall, took about 6hrs and only had a hand full of screws left over... its all good now.
Old Oct 1, 2007 | 03:59 AM
jbrew's Avatar
Thro them left over screws on top of the dash - maybe they'll end up in the right places
Old Oct 1, 2007 | 08:20 AM
Tumba's Avatar
huh!
did i say something stupid. Weren't you talking about your odometer lights not working.
Old Oct 1, 2007 | 06:42 PM
Bartman55's Avatar
there is a little adjuster gear that is connected to a bright with bracket under the steering wheel and depending on which way you turn it it will adjust ur gear selector
I had the same problem after i did my heater core, and it took some smart thing to figure this little problem out!
Old Oct 1, 2007 | 07:01 PM
uknigel2's Avatar
Its not that bad of a job. Almost the same as the blend door. Takes about 6-7 hours. look in the hvac section and you will find a set of instructions making it easy. Get a blend door repair/replace kit at the same time as they start to fail after 7 years, mine lasted 9.
Do it before winter sets in, you will get cold!
Old Oct 1, 2007 | 07:02 PM
jbrew's Avatar
Wellllllll
