Loss of Power!
I had all the COPs in my 1997, 5.4L engine changed today because I had a slight misfire and noticeable power loss. However the problem is still there. When I start the truck and its idling, you can hear a misfire and when driven it has lost some of its power. I changed the plugs also.
What other things could be causing this power loss/ misfire? My mechanic is saying a vacuum leak probably inside a valve, which he is saying couldn't be repaired. What do you guys think? Its not throwing any codes at least not yet, will check it again tomorrow. Any suggestion is appreciated.
