Loosing Acceleration
Old Aug 3, 2007 | 02:01 PM
camdenlake's Avatar
Wires
I would go oem. Its what it was built with and they last preatty good. If you had it mod'd preatty heavy then some aftermarket highend wires would be more suitable. OEM plugs and wires all the way.
Josh
Old Aug 3, 2007 | 03:12 PM
bpkingcobra's Avatar
Thanks for the advice guys. I'll let you know how things go after it's all said and done!
Old Aug 4, 2007 | 04:56 PM
Okay guys here's the scoop. I found out that the sparkplugs i have are the Autolite Premium brand. I checked several different areas for the wires and the only place that carried the OEM Motorcraft were the dealerships - but they didn't have any in stock and would take a couple of days for them to come in. I couldn't wait so i purchased the Autolite ones from Advance Auto Parts.
We changed out the wires and took it for a drive. The truck runs perfectly now! But what a pain in the *ss it was to remove the boots and try to thread them through all the wiring and removing clips was another hassle. None the less once it was all said and done we kicked back and enjoyed a
Thank you all for your tips and suggestions - you guys rock!
Old Aug 10, 2007 | 02:05 PM
Just wanted to give you all an update on this issue. Ever since changing the wires, everything is still running smooth. looks like that was the problem all along.
Old Sep 12, 2007 | 05:09 PM
Just want to give you guys one last update. Since i made the changes i haven't experienced anymore hesitation problems. Everything is still running smoothly!
Thanks again for all your advice!
