5.4l Dohc
Old Jul 10, 2007 | 03:25 AM
Raatikainen22's Avatar
5.4l Dohc
would it be worth the trouble to swap out a 5.4L DOHC engine from a navigator and put in my truck? is it possible? this is just a wouldn't it be cool to try this kinda question..
Old Jul 10, 2007 | 05:23 AM
jbrew's Avatar
That would be awesome -
A donor vehicle is the best way to go - If that's not in the cards you need the complete engine, front accessories to flywheel - Navigator throttle cable and cruise control cables. Torque converter and ECM needs to match which ever transmission you have (4R70w ,4R100 or E4OD)
Comp Cams would be nice - 106060 or 106100. ?? There's gotta be a better grind ??
Can't use the Navi oil pan you have to use the F-150 oil pan and oil pick up tube.
The MAF to get would be an 90mm along w/ 42lb injectors .
Harness - plug and play - a lightning fuel pump or a Walboro .
It will be fun fitting in longtubes - but I would make it work somehow.
So , I 've thought about it..
Old Jul 10, 2007 | 06:26 AM
polpilot's Avatar
Thumbs up
Thats exatly what i plan on putting into my truck some day. im kinda glad im not the only one.
Old Jul 10, 2007 | 06:58 AM
built54's Avatar
It would be 100% worth it. A turbo lightning made almost 1000hp easily with a STOCK 5.4dohc engine. Not even close to possible on the STOCK sohc.
Old Jul 10, 2007 | 07:55 AM
Faster150's Avatar
well ford went away from the 5.4 in the GTR now the are using a 4.6 with a big bore kit. they called the 5.0 cammer it makes 440hp compared to 380 the previous 5.4 made. so i guess it all comes down to what kinda money u wanna spend.
Old Jul 10, 2007 | 08:34 PM
Veteran: Army
X2 with decent ported and polished heads that'll come close to the '99 cobra R power and torque
Old Jul 10, 2007 | 08:47 PM
RYAN24's Avatar
not good if you wanna tow/haul...that is if he still plans on using it as a truck. if not the nav 5.4 would better suit as a truck engine... Just my .02
Old Jul 11, 2007 | 02:15 PM
Thats ridiculous!! where did you hear that!?
Old Jul 11, 2007 | 02:22 PM
I guess so!! It would be sweet.. I wonder what the costs of all this would add up to? I am very good friends with a man that owns a motor shop.. They do great work.. I think i could get a pretty good discount price from him..
Old Jul 11, 2007 | 03:11 PM
Faster150's Avatar
hes looking for speed not tow haul
