Project In The Works
Old Jul 8, 2007 | 10:19 PM
charic09's Avatar
Hey my fellow Ford boys hows it going? I kind of feel like I am hogging the board here but annyways as lots of you guys probably know I own a 1997 F-150 Super Cab 4x4 with a 4.6L V8. It has over 300k on it and I want to start a project truck for off roading. I am in the works of getting the motor running its a rebuilt engine from ford that blew up on me with only 50k and I rebuilt it again and am in the process of getting it running so the engine is good. The body has a coup[le very tiny rust spots hardly noticeable and the fram etc is in awesome condition some of the under body of the truck is still coated with that black finish and it rides very solid. The old guy I bought it off drove it on highway only. I also rebuilt the 4x4 system too. Anyways I want all you guys to list me some things to get me started. Stuff like power addons but I wanted to keep the engine naturally aspired. I have an exhaust with the cats cut its dual all the way back from the manifolds (plan on getting headers soon!) so just list me everything from motor addons to suspension parts. I am thinking this could get fun so let me hear your 2 cents worth.
Old Jul 8, 2007 | 10:21 PM
built54's Avatar
Ill help ya when the engine. Long tube headers, stage II heads, comp cams, custom tuning, efans, intake, injectors, fuel pump...
Old Jul 8, 2007 | 10:25 PM
charic09's Avatar
What kind of mula is that gunna run me and what am I looking at for HP and Torque gains???
Old Jul 8, 2007 | 10:30 PM
built54's Avatar
everything I did in my sig. gained me 105hp over stock... I have no idea how much I spent on everything, i dont want to add it all up.
Old Jul 8, 2007 | 10:33 PM
jbrew's Avatar
I do - ALLAWT!!
Old Jul 9, 2007 | 02:47 AM
charic09's Avatar
When I rebuilt my engine I put these pistons back in. Do you think I will see any gains at all in hp or torque (when i get the engine running right)?
http://www.federal-mogul.com/en/Afte...dPowerPistons/
Old Jul 9, 2007 | 03:47 AM
charic09's Avatar
Also, which air intake system would be the best to get. Does your MAS and the other sensor thingy just plug right into these air intake systems?
Old Jul 9, 2007 | 03:49 AM
jbrew's Avatar
AF1 - you use your MAF assemly so , yes.
A little advice - get a cold air intake.
Old Jul 9, 2007 | 06:36 AM
charic09's Avatar
Checked it out and I like gunna order one in the morning!!!
Old Jul 9, 2007 | 06:38 AM
charic09's Avatar
Not such a good idea I don't think not where I live. I live in northern BC and it gets quite cold here in winter might do me more harm then good I think.
Old Jul 9, 2007 | 06:52 AM
built54's Avatar
no, you will be fine.
Old Jul 9, 2007 | 11:13 AM
redneckcowboy28's Avatar
ok well those are good fer horsepower and torque ideas but you said it will be an offroad vehicle rite??? if so wat kind of terrain are u looking at??? wat size tires??? GEARS will make the most difference and while you are in there mite as well put in some traction adders. the best offroad trucks are built from the ground up literally start with the ground u will run on then go up the truck from there sorry to rant just had to put in my two cents everyone wants power but if it only spins the tires in mud or on wet rocks it not helpin much
Old Jul 9, 2007 | 01:54 PM
built54's Avatar
gears would be a good addition, but with what i listed, its not only going to spin in the mud or wet rocks.... trust me.
Old Jul 9, 2007 | 02:24 PM
Klitch's Avatar
for the 4x4 option, your ideal setup for tractions probably going to be something like a detroit locker with nospin or whatever. 4wdcentral has them for about 650 shipped.
also for your front end i would highly suggest a selectable locker.
if your keeping a 4.6 in it and going with 35" or larger i would suggest 4.88 gears. sure they are a little steep on the freeway but you wanna play and have some extra flexing room?
how hard core you wanna go in the suspension dept? articulation? 4-link it.
Old Jul 9, 2007 | 10:09 PM
charic09's Avatar
I don't want to go crazy hard core with it its going to be a gradual build up. I won't be mud bogging it in 5 foot mud holes or nothin. What I want is a truck that is safe and good for the highway, but be able to go over some off road terrain too like old logging roads and stuff ya know and be able to handle fairly tough obsticles that a stock truck wouldn't be able to handle. I want to be able to leave my buddies with their newer stock trucks ya know almost for bragging rights if anything.
