starter problem
starter problem
I am working on 2000 expedition with the 5.4. When I start the truck the starter will not disengage and the engine is running. The starter is new...the battery is new. Has anyone had this problem? Does anyone know what it might be? Thanks
Originally Posted by 1993F150
...I have power to the solenoid after the truck is running.
Ford redesigned the MLPS because water intrusion was causing failures. If you replace yours, plan on pulling each pin out of your harness connector & installing them in the connector shell provided with the new-style MLPS. It's not as hard as it sounds, but there's not much room or wire to work with.
You can read about that redesign in this thread.
