Blew the head gasket
Looks like the head gasket went - what do you think ?
How long can I go before I should change it?
Runs fine ... I haven't checked the compression yet..
Hey jbrew you getting any coolant in the engine?
It doesn't look to terrible.I would run it unless it's leaking coolant in the oil.
I can see a damp spot on mine also but they don't drip or anything
This is a good time for you to do the PI head swap
No coolent in the oil - oil always looks new when I check it - still doesnt use any between changes . I compression checked it in 2001 and recorded it in the manual - The last check this past winter , it hasen't changed - to close in the numbers to say theres a significant difference . It's been a good motor and used that Castrol 3w 30 most of its life. I ran a case of Amsoil thru her once - only because it was a gift .. Who gets oil as a present ? ME - Hey it's better than a box of rocks
Thanx , I'm not that worried about then..I'm trying to hold out until I aquire another set of heads and headers to them both at the same time..
Agreed ! 219,000 here - Castrol + Motorcraft Filter every 3000 miles
I swapped out a motor (3.8L) in a Windstar a couple years ago for a woman. The Woman admitted that she never changed the oil
The van had 60,000 miles before it blew a nut - What happen was it stopped cycleing oil - period. The pickup screen totally plugged up - there wasn't even a pin hole showing..
Sad thing is , I told her the oil has to be changed , she replied - that's a mans job, ieyiyiii. Well , I told she better get one of those ... I know she still doesn't change her oil and I doubt she's had very much luck with men - she could scare hungry dogs off a meatwagon - no problem...
Originally Posted by Kevin24
Man i have some catching up to do, 83,000miles on mine
I have some drilling to - frickin manifold flange bolts, both sides broke off of course
I need to get one of those "DrillDoctors" I think - or a torch
Originally Posted by jbrew
You'll get there - alls yuh have to do is maintain it .
Broken bolts,are ya taking it apart?
Start soaking with Mouse Milk. I work on aircraft and I use it all the time on exhaust bolts that have the same problem. I use MAC Straight Flute Screw Extractor Set 5663ES only the straight and tap it with a hammer and it forms a square inside the drilled hole. It usually comes out easy. If you do not use the straight and it brakes you will have fun getting it out.
Scew it, I'll do it up right this winter when I do the head and headers..That liquid weld is good for only 700 degrees - hope it holds out that long - it's clamped as - well..
Originally Posted by keith97xlt
gotta chime in in that scare the dogs off the meatwagon comment lol.
She was just Fugly
219k on original headgaskets you got your use out of her.
That's what I was thinking..
MAC tools
I'm praying if I get her wire wheeled good on each side of the broken bolt - apply heat and use a pair of vise grips on what's left it will come out . I'm not betting on it tho - prolly have to drill it..
