The Mysterious Ford Gas Gauge
Originally Posted by Gray Ghost
...same thing here... and it pisses me off... i can do 3 days with the needle not even moving off of the F and then it goes down to half in a few days ...
I haven't had an F150 fuel tank apart before. Anyone seen (or have pics of) the float?
(Love the new fuel/wallet gauge, btw.
Glad my other vehicle gets ~28 mpg!)
Ford does that to promote sales on demo models. That way the salesman can say it's gone 250 miles on only HALF A TANK with a 5.4 engine... Consumer proceeds to flip over what awesome mileage, and buys the truck. Next day they realize there is only 50 miles on the second half....oh well.
Our 07 Explorer doesn't do this. Gauge there seems to be pretty static in it's rate of decent. But my '93 is like that. Moreso for the front tank than the rear.
Funny, my boat and jetski are just the opposite. Drops like a rock to half, then trickles down the rest of the way.
I had 2 S-10's before this and they all did the same thing. Slow the first half and fast the second. I learned along time ago to use the trip odometer. I have only had 4 tank fulls so far and get 20.5 to 21.8. mpg. 25 miles each way to work and all 2 lane road.
same thing here... and it pisses me off... i can do 3 days with the needle not even moving off of the F and then it goes down to half in a few days and it'll be at 1/4 the next day and i hit E a few miles after it hits 1/4!?!?!? WIERD!
Originally Posted by JPRempe
It's completely accurate. It accurately judges the fuel level in the tank according to the shape of the tank and the amount of fuel in said shaped tank.
For starters, VERY very few new cars come even close to that mileage before being sold, and used cars....well, are you kidding? It just doesn't work that way.
I worked at a dealership, and I know fully well that the cars come from Ford with a few gallons, and rarely get refilled at a good dealer. If they do, they get typically $5-10.00 worth of gas while on the lot... so that entire concept wouldn't work.
Well, at any rate, I sure hope it was a joke
thank you for understanding what i was saying.
If youve ever looked at your gas tank, its shaped like \ / (in an overall shape)
So there is physically more gas in the top half of the tank then there is in the bottom of the tank.
So the gauge is very accurate for the vessel its in
With a rectangular tank and a sending unit that travels vertically, the gauge should read accurately... BUT -
Originally Posted by F150NJ
...<Snip> My guess is that when we fill our tanks, we fill them above the upper limit of the float. If the tank is being filled above the upper limit of the float, the gas above it must all be used before the float even begins to move down and the needle moves off of 'F'. That makes the first half of the tank seem to go more slowly than the second half.
I haven't had an F150 fuel tank apart before. Anyone seen (or have pics of) the float?...<Snip>
Use the odometer - I am always amazed at how consistent my mileage is, as long as I don't run it way faster than usual.
I've owned perhaps 20 vehicles in my life (not all Fords), and the gas gauges all do the same thing. I go by total miles driven.
When you fill it up, the level of fuel is actually above the float (well, many newer cars don't have a float, they have a capacitance induction sensor as used in aircraft). You probably have a gallon or two in the fill pipe, and then you have to burn off a gallon or two in the tank before the float can move.
Originally Posted by B-Man
The tank is NOT V-shaped at all - I've had several of them out doing fuel pump upgrades. It is long and rectangular in shape. (2WD versions anyway)
Trust me the gas gauge is accurate.
Like i said, its not exactly a \ / shape, but yes there are steps in the back of the bottom. Dont make me go crawl under my truck and take pictures...
haha they are called baffles.. they keep the fuel from shifting so much going over bumps.
