99 4.6 ping
99 4.6 ping
Need help 99 f150 pinging at low throttle and I can set at idle and give the throttle a quick push to the floor and the ping is the first thing you hear before the engine reves no pinging any other time cleaned M.A.S also ran sea foam through vacuum line on intake more than once it will not ping on the highway or pulling a trailer also need to know if anyone has been advised to use BP Fuel
Several engines will ping whenever giving the throttle a quick push to the floor. The computer system takes a couple of milli-seconds to adjust the timing to the signals it receives. This is normal. This slight time of ping is harmless as long as it goes away during computer adjustment.
