Got Troyer 16" Performance E Fans Today??
Got my E -Fans For my 02 Screw, the instructions are more than I can handle. Should I just take it to Ford and let them put them on??
02 F-150 Screw, 4.6L, K&N FIPK, FlowMaster 40 Series S/I D/O troyer Superchips Custom Tuning 5-program 4-bank Performance Chip! Dark Shadow grey, Access Lite Rider Low Profile Tonneau Cover
Thanks For the Help, and yes, I did get t
he new mounting Bracket with it!
I'd look in the phone book / ask a friend to recommend a custom shop to do it before I'd take it to a dealer for something like that. Pretty sure the ATL has to be full of custom truck shops.
Good Luck!!
Good Luck!!
Good Luck!!
Good Luck!!
thanks I'll find someone!
I would just pay a shop 15 bucks to take the stock fan off. Its a giant PITA to remove. Your truck will be just fine driving home without a fan as long as you keep speeds above 25. And dont sit for more then about 2 minutes
Unless you really just dont want to do it, then yeah anyone that knows anything about cars/trucks should be able to do it.
Originally Posted by glc
You don't need a custom shop - any competent mechanic can do it.
Originally Posted by PowerHorse21
thanks for ya'lls input, i'm having the Ford Dealer do it today as we speak! Hopefully the gains will be what troyer claims from a minimum of 15hp to 20hp at the rear Wheels! Thanks Ya'll!!
haha keep wishing on that one
Wait, you are going to take the stock fan(s) off and replace with electric. This will give you better cooling and lower water temps a bit hence keeping the block a bit cooler. This will add 15-20hp at the wheels? If that were the case then cars driving in the winter would have a minimum of 15-20 hp too? They may actually have a little more than when its 90deg out but thats due to the density of the air not the temp of the block. I don't get it.
5-7 is much more accurate then 15-20
and yes it can cool the water faster, and help with heat soaking after your turn the truck off. But it only cools the water in the radiator, so unless you do a cooler thermostat too, then you really arent cooling to a lower tempature...
Originally Posted by robertmII
WoW, that's a lot of hp being used up there. I've heard of 5-7hp never that much. That is a pretty cheap hp bump if its really that much.
The last thing you want to do is replace the stock 194 degree thermostat.
My truck makes peak power and torque @ 203 degrees. I picked up a modest 16 HP with Mikes efans on my truck (dyno proven HP too). My truck was and still is used for many of the products Mike endorses. You could even say that it is a Dyno Queen of sorts....
Leave that stock thermostat in there !!!!!!
Originally Posted by Marc Carpenter
WRONG....
16 peak hp at the wheels is fairly sig. What about torque? I need more power to pull loads not really accelerate off the line. Also, what is the cost on this option? (I guess I could just go to his site).
