97 4.6 stalling
Old Jun 17, 2007 | 02:13 PM
keith97xlt's Avatar
97 4.6 stalling
hey guys my truck stalls anytime i give it gas or throw it in gear. has all the symptoms of a clogged fuel filter so i went ahead and changed it. still same problem. it starts ans idles fine.
Old Jun 17, 2007 | 02:20 PM
Any codes?
Old Jun 17, 2007 | 02:38 PM
keith97xlt's Avatar
no CEL or anything thats why i thought ut was fuel filter or something simple.
Old Jun 17, 2007 | 02:55 PM
jbrew's Avatar
Your inertia is tripped - reset it.
behind the pass. kick panel.
Old Jun 17, 2007 | 02:57 PM
jbrew's Avatar
If that by chance isn't the prob , check the fuel relay (you can swap relay's - there the same ) also check the fuel relay MAXI fuse.
Everythings under the hood in the PDB. If you neeb to know there local , just ask..
Old Jun 17, 2007 | 02:59 PM
keith97xlt's Avatar
ok ill give that a try.
Old Jun 17, 2007 | 03:00 PM
jbrew's Avatar
Give her some gas while tapping on your IAC - it might be stuck..
This is freaking your air metering tables out - so reboot after changing anything up..Pull the maxi #24 orange 30amp, PCM fuse. Thers also a little 5amp PCM fuse under the dash - center row second from the bottom.
Old Jun 17, 2007 | 03:10 PM
keith97xlt's Avatar
just reset it. it started up fine, hesitated a little after i put it in gear. then it took of like it should. first stop sign she starts sputtering. it mimmicks just like a clogged filter. would a bad relay cause problems like this??? i did get a CEL this time though. i dont know if i can make it to autozone for them to read. im thinking possible TPS SENSER??
Old Jun 17, 2007 | 03:16 PM
jbrew's Avatar
It will usually shift funny with a bad TPS, but run good - I'm thinking IAC..
Old Jun 17, 2007 | 03:30 PM
keith97xlt's Avatar
just pulled those fuses still giving me a hard time. i tapped the i.a.c while giving it some gas ,still same stalling.
Old Jun 17, 2007 | 04:13 PM
jbrew's Avatar
If you still have a cell light on - Auto zone will rent you there reader - if you can't get the truck there , they will also come to you if your in there area..
Double check - make sure everythings plugged in - clean the MAF , maybe it was contaminated , reboot again - Pull both cables and let it sit for 15 minutes .
ALWAYS reconnect the positive cable first when you do that..
You Know - It sounds like it's missing now - but it shouldn't be . However , it's a posibility..
A reader would help allot .
Old Jun 17, 2007 | 07:51 PM
keith97xlt's Avatar
alright i ll borrow that reader and get back with the results.
Old Jun 18, 2007 | 09:04 AM
keith97xlt's Avatar
hey jbrew. you will love my stupidity. i got the scanner. and it came back mass air senser low input.ok now i have a starting point. i go to remove the air filter etc...i look down and see a plug not connected. i follow it and sure enough it was the dam mass air senser. i must have unplugged and forget lol. its the 3, prong pluf under the filter. you dont see it so..... dam that would have been a 150-200$ mistake. feel free to break my *****. i deserve it on this one.
