weird rattling noise????
Old Jun 13, 2007 | 08:30 PM
808skindiver's Avatar
i have a 98 f150 4.6. when i drive the truck it runs good but when i go up steep hills and when i rev at 3000 rpms my engine starts to make a rattling sound. it sounds like its on the outside of the engine.
Old Jun 13, 2007 | 09:37 PM
TexfordD's Avatar
Heat shield over convertors?
Old Jun 13, 2007 | 11:45 PM
basschamp's Avatar
yeah sounds like your cat may be breaking up inside
Old Jun 14, 2007 | 01:22 AM
jbrew's Avatar
prolly those damn heat shields that are spot welded around the cats.
A year and a half ago I ran band clamps around the rear cats to keep them quite - think they were 7 " B Clamps. - That lasted till about a month ago and now I can't do anything to quite them down .
Well , Except - I cut the rears off , kept the fronts - No dice , those are making that irritating chirping sound and have to off those too.
Eventually you'll want to get rid of all 4 cats and replace with a Magnaflow cat or similar - You only need one to pass emissions any way and you won't throw a check engine light if you get one good one for each side. Make sure with whatever you get , the heat shields are welded solid around the perimeter . Spot welds don't last..
You can temporarily band them up for now - 3 band clamps a piece for the rears.
Actually - heres a pic from a TSB about this problem -
Here my rears - when I started to band them up -
Good luck
