What Happened?? Please Help
Old Jun 11, 2007 | 10:38 AM
02SUPRCRUE's Avatar
Over the last month every time I start my truck I'm getting a tapping sound for about 2 min then it quites down. I had a a 97 Expy that had the same thing and the dealer/Ford replaced the engine. I was told that the sound was the piston slap. On my Expy the problem started within the first 10K miles and only when it was cold out. My F150 has a 5.4 also and I just rolled 45K miles and it is just starting now, even with warmer temps outside. Is this the piston slap again or someting else. Thanks
02 F150 Super Crew Lariat FX4 White & Silver
5.4 /w Roush Cold Air Intake & K&N filter
3.55 LS
Flowmaster Cat Back
JBA Silver Cat4ward Headers
Rancho RSX's
Rancho Steering Stablizer
Hellwig Rear Anti Sway Bar
Lightning Tails
Outland Sport Bumper Guard
Hella 550's
Silverstars
Superchips 9100 Micro Tuner c/o Troyer Performance
Underdrive Pullies c/o Troyer Performance
Mag-Hytec Trans Pan
Old Jun 11, 2007 | 01:02 PM
sysman_rick's Avatar
Post
What oil filter & oil r u using ? The Motorcraft oil filter has a improved anti-drainback valve to prevent dry starts.
Old Jun 12, 2007 | 10:01 AM
02SUPRCRUE's Avatar
The filters is a Motorcraft and the oil is Havoline. Thanks
3.55 LS
Flowmaster Cat Back
Rancho RSX's
Lightning Tails
Hella 550's
Silverstars
Mag-Hytec Trans Pan
Old Jun 12, 2007 | 10:07 AM
Faster150's Avatar
un fortunately piston slap is really common with the 5.4's and theres no really good fix for it. but they last for many years with that problem so i wouldnt worry to much about it but some things that might help is making sure the spark plugs all face the same direction in the chamber which is hard to do but that ensures that the spark and flame start and end at the same point in the chamber each fire. also get the injectors flow balanced.. its pretty common for them to come unbalanced from the factory and cause one cylnder to be lean and another to be rich. u could also try switching to a 10w30 oil
Old Jun 12, 2007 | 10:20 AM
jbrew's Avatar
You might wanna try a full synthetic.
Old Jun 12, 2007 | 01:04 PM
02SUPRCRUE's Avatar
Thanks for the suggestions...any more? Faster150 I thought I heard Ford was replacing the engines, is this true?
Thanks!
3.55 LS
Flowmaster Cat Back
Rancho RSX's
Lightning Tails
Hella 550's
Silverstars
Mag-Hytec Trans Pan
Old Jun 12, 2007 | 09:55 PM
hcmq's Avatar
broken exhaust manifold bolts on the passenger side. (most likely)
or a plug getting ready to launch
Old Jun 14, 2007 | 09:28 AM
02SUPRCRUE's Avatar
HCMQ
Thanks, but I'm sure it not the exhaust manifolds. The headers are fairly new and I checked all the bolts and they are good.
Any other suggestions...anyone
3.55 LS
Flowmaster Cat Back
Rancho RSX's
Lightning Tails
Hella 550's
Silverstars
Mag-Hytec Trans Pan
Old Jun 26, 2007 | 10:42 AM
02SUPRCRUE's Avatar
Alright so I did a search and read as much as I can regarding Piston Slap. Does anyone know what or if Ford is doing about it?
Thanks!
3.55 LS
Flowmaster Cat Back
Rancho RSX's
Lightning Tails
Hella 550's
Silverstars
Mag-Hytec Trans Pan
Old Sep 28, 2007 | 09:45 AM
02SUPRCRUE's Avatar
Update
OK so I finally took the truck to the dealer to check the knock noise and a few other issues. Figured I get my monies worth from the extended warranty.
Turns out the lifter(s) on the right side were the problem. So for my $50. deductible I got 8 right side lifters, lower ball joints, and the Auto Temp head unit replaced. Not bad for $50.
3.55 LS
Flowmaster Cat Back
Rancho RSX's
Lightning Tails
Hella 550's
Silverstars
Mag-Hytec Trans Pan
Old Sep 28, 2007 | 11:19 AM
BLUE20004X4's Avatar
Don't forget that headers will make ticking noise anyways compared to cast iron manifolds, but if that was it, that 50 bucks was a good fix to me.
Old Sep 28, 2007 | 11:34 AM
Lifter failure - that may be a warning to you that you are not using appropriate oil and/or not following appropriate change intervals.
Old Sep 28, 2007 | 12:11 PM
02SUPRCRUE's Avatar
BLUE20004X4
The noise was not the same as the header ticking. Several people had suggested the same thing until they heard the noise. Even the mechanic didn't hear the noise at first the knocking / tapping only started after the engine was running about 30 sec. and only lasted less than 3 min unless it was around 50F.
GLC
Thanks for the info. Oil changes are done every 3k - 7k depending on my driving conditions. Have only ever used 5-20.
3.55 LS
Flowmaster Cat Back
Rancho RSX's
Lightning Tails
Hella 550's
Silverstars
Mag-Hytec Trans Pan
Old Sep 28, 2007 | 12:36 PM
If you are going to push the oil to 7k, you should be using a semi-synthetic at the very least. Motorcraft 5W20 semi is just as cheap as dino and Walmart carries it.
Old Sep 28, 2007 | 01:37 PM
02SUPRCRUE's Avatar
Hey GLC thanks! I actually looked at the Motorcraft 5-20 semi at Walmart and found a 5 qt and 1 qt bottle together were cheaper that the Havoline, Penzoil, Quaker Sate & Castrol dino. Go figure
3.55 LS
Flowmaster Cat Back
Rancho RSX's
Lightning Tails
Hella 550's
Silverstars
Mag-Hytec Trans Pan
