o2 sensors?
Old Jun 3, 2007 | 08:19 PM
ennsf150's Avatar
o2 sensors?
the other day my check engine light came on, and i noticed my truck nearly dies when i put in gear, Its even stalled completly the other night when i put it in reverse. Its got about 130k and im pretty sure the o2 sensors have never been changed, could that be the problem?
Old Jun 3, 2007 | 09:15 PM
torkum's Avatar
What are the codes????
Old Jun 3, 2007 | 10:51 PM
ennsf150's Avatar
I have no idea. I guess a tuner could show me the codes, I've been wanting to get one.
Old Jun 3, 2007 | 10:58 PM
jbrew's Avatar
Auto Zone will read your codes for free if the lights on - is your check engine light on?
Old Jun 3, 2007 | 11:02 PM
ennsf150's Avatar
i didn't know they could do that, but yeah the light is on.
Old Jun 3, 2007 | 11:07 PM
jbrew's Avatar
That's good , yeah , auto zone will bring a scanner out and plug in to retrieve the codes for you - this gets them business
When they do so , get the numbers from there scanner and write them down - they do not always cipher the numbers correctly . We do here , so report the numbers back here and we can tell you what needs to be done .
Old Jun 4, 2007 | 08:34 PM
ennsf150's Avatar
The code # is p1405.
Old Jun 5, 2007 | 12:01 AM
jbrew's Avatar
Thats your DPFE Sensor most likely . It's that rectangle box looking thing with the two rubber hoses plugging into the bottom of it. Check the condition of the hoses - if you disconnect make sure you hook them back up right.
Your DPFE may be plastic and black.
If the hoses check out , take it off and make sure the tubes leading into the sensor isn't plugged up.
If you decide that you need a new one , get it from a dealership , Ford updated the DPFE and the new ones can only be had at the dealerships as far as I know..
Old Jun 5, 2007 | 10:25 PM
ennsf150's Avatar
the guy at auto zone thought it was the egr valve, but I'll check the dpfe sensor. Thanks for the advice.
