Fast startup, valve traine noise '05 5.4L
Old May 27, 2007 | 02:49 AM
Nils128's Avatar
When i start my truck it has a hard start up equilivaent to starting the truck with your foot on the throttle. I wouldn't mind this but it starts so fast you can hear the valve train due to the lack of oil. This can't be good for the engine. Is there a fix for this?
Old Jun 11, 2009 | 08:30 AM
bigtoyz30's Avatar
Did you ever find anything out about this issue I have the same problem
Old Jun 11, 2009 | 10:09 AM
What brand of oil filter and what weight and brand of oil are you using?
Old Jun 14, 2009 | 01:50 PM
Nils128's Avatar
I'm using a fram extra guard filter and 5-30 mobil one full systhetic.
I'm not sure if this can be avoided. It seem like it is just the way Ford has the einge start?
Old Jun 14, 2009 | 01:58 PM
keith97xlt's Avatar
first thing is to get rid of that fram filter and get a motocraft on there.
Old Jun 14, 2009 | 02:09 PM
Switch back to 5-20 oil. The VCT systems on these 5.4 3v engines do not work properly with any other viscosity, and you're only asking for problems. Also, check the flat rate tech link in my sig.
Old Jun 14, 2009 | 02:34 PM
The 5W30 Mobil 1 is the grade that's been failing tests - if you want to use Mobil 1, use 5W20 EP, and either a Motorcraft or Mobil 1 filter.
Old Jun 14, 2009 | 07:34 PM
risupercrewman's Avatar
Use only 5w-20 viscosity oil, & a Motorcraft FL-820-S filter, & that will solve your problems!
Old Jun 14, 2009 | 09:49 PM
TJ05FX4's Avatar
When I first got my truck about 6 months ago, mine did the same thing. First cold start in the morning it would knock a little bit before the oil would get up there.
I changed the oil within a week or so of owning it and followed the owners manual w/ the 5W-20 Motorcraft Syn Blend and Motorcraft filter. It has never made a single sound or noise again on a cold start. I've always been a pretty big believer in synthetic oils, but from what many have said and researching this site intensely, the Motorcraft syn blend is the best out there for the 3v 5.4L.
Old Jun 15, 2009 | 05:52 AM
Full Synthetic, will always yield better results than a Syn-Blend! What is important is using the right viscosity & Filter! Even MotorCraft makes a full Synthetic for the 5.4 3v!........
Old Jun 15, 2009 | 10:19 AM
TJ05FX4's Avatar
Wasn't trying to argue with you. I was simply stating what worked best for me and what I found searching this site quite a bit about the subject. No need to get into a viscosity and oiling debate.
Old Jun 15, 2009 | 10:24 AM
Nils128's Avatar
Thanks, i'll give it a try.
Old Aug 29, 2009 | 11:27 PM
MotoMike's Avatar
I've got a 05 5.4 also.........engine starts fine, will idle at about 1400 rpm or so for about a minute when cold before dropping to regular idle speed.
Old Aug 30, 2009 | 02:26 PM
Normal.
Old Aug 30, 2009 | 06:16 PM
Power Kid's Avatar
Mine does it not matter what filter/oil.
