What is this...?
Old May 24, 2007 | 01:27 PM
ducatiduke's Avatar
What is this...?
I changed my oil and found this... This is the first time I changed the oil (dealer did the first one)... This is a 2006 F150 SuperCrew with a 5.4.
http://public.fotki.com/ducatiduke/o...302medium.html
It looks like it should be plugged into something...
~A
P.S. This shot is from under the truck.
Old May 24, 2007 | 03:00 PM
bamorris2's Avatar
Do you have a wider pic of the engine area? Then I can compare it to mine to see what/where it goes.
Old May 25, 2007 | 03:01 PM
jward's Avatar
You know, I remember seeing a thread about this some time ago. From what I remember, it's a harness that is used only in the 4X4 trucks. Seems all trucks come from the factory with it, but only 4X4 have it connected. If yours is a 2X4, probably no concern.
Perhaps someone else remembers the thread, or knows for sure.
Old May 25, 2007 | 05:45 PM
Quintin's Avatar
It looks like the purge/fill connector. It's used to bleed the brakes when the vehicle is assembled.
Old May 25, 2007 | 06:58 PM
Camarothatcould's Avatar
Looks like its already connected, a relay type thing...
Old May 25, 2007 | 07:06 PM
bigdad8214's Avatar
What he said.
Old May 25, 2007 | 07:41 PM
Shane1's Avatar
Thats a leaverite
.leaverite there
Old May 25, 2007 | 07:50 PM
Quintin's Avatar
It's just a blank plug on the male end to keep dirt and water out of the connector.
Old May 31, 2007 | 07:17 PM
ironman1977's Avatar
that connector used to be pluged into a transducer on the power steering presure line that is no longer there (i.e Ford removed the transducer from production but wiring remains the same)
Old May 31, 2007 | 08:33 PM
MASTERTECH's Avatar
what is this
Its simply a dummy plug. don't worry about it.
Old May 31, 2007 | 11:01 PM
Gotts2BMe's Avatar
Originally Posted by Shane1
Thats a leaverite
.leaverite there
No I believe thats the cuzifit.
.Cuz if it wasn't there you wouldn't ask
Old May 31, 2007 | 11:56 PM
ducatiduke's Avatar
Thanks for everyones replys... Yes it is a 2x4... So, looking at all of these, I am figuring i am ok.
Old Jun 1, 2007 | 11:49 AM
T Ellenberger's Avatar
Could be a "gozinta".
Cuz it looks like it goes in ta da other thing.
Old Jun 1, 2007 | 12:27 PM
LRG's Avatar
LRG
LOL I'm sure Larry the Cable Guy would feel right at home in here!
