Orange Coolant? Where to buy?
Old May 15, 2007 | 01:20 PM
fishx65's Avatar
O3 FX4 is ready for a coolant change. Where should I purchase the orange stuff. What's the difference between orange and green coolant? Any tips or tricks that will help with the change??
Thanks, FishX65
Old May 15, 2007 | 02:50 PM
keith97xlt's Avatar
the green coolant is fine. go with prestone premix.
Old May 15, 2007 | 03:00 PM
DDan1967's Avatar
I don't understand why anyone would go with Premixed Antifreeze.
Why pay twice as much for 1/2 a gallon of water and 1/2 a gallon of Antifreeze in a 1 gallon jug.
Is adding water really that difficult.
Just my 2 cents. But I don't understand.
Doug
Old May 15, 2007 | 03:17 PM
keith97xlt's Avatar
same reason people drive 5 miles out of there way to save 5 cents a gallon a gas. the guy wanted a answer on antifreeze. not economics.
Old May 15, 2007 | 04:22 PM
scott1981's Avatar
Old May 15, 2007 | 04:49 PM
tex_n's Avatar
Doug
I've always bought the "real" stuff, mainly because it only became an option a couple of years ago. The last time I flushed and refilled, I used the premixed for convenience. I know my concentration is 50/50. I used to work on older cars that always leaked, and I'd top em off with water once a month. Who knows what ratio I was at after 3-4 months. Also when I did have to pull a radiator, or replace a hose, I'd add a gallon of antifreeze and fill the rest with water. Sometimes it would take a minute of squirting in with hose, and sometimes it would take 5 seconds. Who knew what ratio I ended up with. I guess now that I'm older, money is less of an issue, don't want the hassle....I buy the premixed. Of course I drive newer cars and trucks, so I don't know if I'll ever use that half jug of leftover premixed I have in my garage. It is more expensive, but I think hassle wise, it pays off.
To make this relevant to the original poster, some of the stuff says it's compatible with both types, so make sure you get that kind.
Old May 15, 2007 | 04:51 PM
Quintin's Avatar
Your F150 does not use orange coolant! It should have "Premium Gold" coolant in it, Motorcraft number VC-7-A. Do not go out and get orange colored or Dexcool style coolant.
Old May 15, 2007 | 05:36 PM
Rikster's Avatar
The difference between the orange and green stuff is not that one is premixed and the other isn't. The orange formula is silicate and phosphate free and the green formula isn't. Use the type recommended and only that type. Using the wrong type can cause premature wear.
Old May 15, 2007 | 06:51 PM
fishx65's Avatar
I guess my question should have been, Does Prestone or any other company sell an antifreeze that matches the specs of the Ford Premium Gold that I can purchase at the local parts store? Do most of you guys just use the Motorcraft Premium Gold from the dealer?
Old May 15, 2007 | 08:06 PM
BUZZKILLER's Avatar
Get the Prestone in the yellow jug
that says it is compatible with ALL types of antifreeze and ALL makes of vehicles on the front of the jug. It is the premix 50/50.
Old May 15, 2007 | 10:48 PM
Jersey1035's Avatar
I use Zerex Antifreeze Coolant, G-05 formula. It mets Ford WWS-M97851-A1 requirements. It's in a gold plastic bottle. Same as Ford Premium VC 7-A. All of this info is on the back label. It says Ford vehicles 2002 and newer.
Dave
Old May 16, 2007 | 12:07 AM
Klitch's Avatar
i second the note of buying pure antifreeze and mixing it yourself. it dont take long and its not hard. oh and this isnt an economics statement, its just logic... get more for your money... isnt that what this world is coming to NOW?
Old May 16, 2007 | 12:39 AM
BSL's Avatar
BSL
approaching $3.50 for 85 octane here I'm going to start going to anything that's proven to up MPG, thats the reality of the era of record petro company profits every quarter, you need to get more for your money
Klitch's Avatar
7 billion... whos porkin who now?
Old May 16, 2007 | 12:51 AM
BSL's Avatar
BSL
tell me about it, I need one of those @$$ doughnuts after every time I fill the tank
