diagnostic trouble code b2825
Old May 10, 2007 | 05:55 PM
geoneo's Avatar
I have a 2002 lincoln blackwood showing that there is a diagnostic trouble code b2825 anyone knows what that means?
tks
Old May 10, 2007 | 08:59 PM
projectSHO89's Avatar
How did you get that code?
Old May 10, 2007 | 09:27 PM
Labnerd's Avatar
I think you have the wrong code. The B stands for body code. The code B2825 is for the 2004 Navigator covered under TSB 04114. Liftgate reversing direction when closing in hot ambient temps of 90F+.
Old May 10, 2007 | 09:36 PM
Bluegrass's Avatar
Use your browser and input 'Ford TSB 0471'.
You should get lead to the B 2825 code and it's meaning.
It has a NHTSA # asigned so your dealer should be able to take care of it if you push a little.
It involves the forward/reverse sensing system monitor and may be a falsely activated code that requires dealer intervention.
Nothing big but still should be addressed if you care to..
Question of how you outputted the code; since common readers usually don't have the capability to request codes other than engine PCM codes unless a high end scanner is used.
Good luck.
Old May 10, 2007 | 09:41 PM
Bluegrass's Avatar
Now I have to go back and see if I made a mistake looking!
Later:
Chasing both ways keeps ending to the same info.
And yes it refers to 04 Nav.
If your sure your code is correct.
There seems to be no P code 2825 in any Ford listing.
Old May 10, 2007 | 11:46 PM
geoneo's Avatar
Tks for everyones reply. I got the code from the dealer, i asked them what code they came up with after doing there diagnostic testing and they said b2825. The wierd thing is my truck is in the shop because my automatic tonneau cover doesn't work, and they cant figure out whats wrong with it, and its been 3 days, so in frustration i asked for the diagnostic code and thats what they said, i will confirm it again tommorrow when they open again. Tks everyone for your time i will google TSB 0471 and see what it comes with.
Old May 11, 2007 | 10:30 AM
There's also no B2825 in any of the Blackwood service documentation....
...also, someone needs to move this to the correct sub-forum. It doesn't belong in the ENGINES section
Steve
