"Whistling" noise in cabin...
2002 S'Crew FX4 Lariat 5.4
I'm not sure how else to describe it. It doesn't seem to matter which gear I'm in, but always is the most noticeable between 2000 and 2500 rpm during accelleration, I am hearing a "whistling" noise...almost like a teapot whistle, but a bit lower. It sounds as though it is coming from behind the dash. I thought at first it was a grounding problem with the stereo, but completely removed it and speakers and noise was still present. Thought it was sound coming through ventilation system, but hear it even when set to "off." Sound "feels" like it is coming from behind dash area, centralized behind the stereo.
Anyone else experience this? Heard of this? Ideas on what it might be?
Other than the nuisance, nothing appears to be wrong and its running like a champ...almost a member of the 100k club!
Thanx.
Thanx.
My '93 whistled too when I first bought it. Seemed to slightly increase in volume when the motor lifted off idle, but if the radio was at even a moderate volume you wouldn't hear it at all.
Tuned out to be a rotty vacuum line for the HVAC system, one that goes to the actuator thingy that moves the handle as you turn the **** between A/C, vent, and defrost. I didn't even replace it, a little epoxy on the rotted part and some duct tape around and it stopped completely.
i have the same problem. it did it with the stock intake and still with the new intake. mine does it when i reeli get on it and start gettign up there in rpm's it sounds like a belt squeeling or something. i cant figure it out.
Do a search on whistling or whistle and see a few posts. I know what you mean to a T, however, mine happens around 1600-2100 area commonly. A few have pointed in the direction of idler and or tensioner pulley bearings bieng crap, I don't know because mine has almost vanished now. If you wait long enough, problems fix themselves.
A/C - Whistling Noise When Driving With A/C OFF
Article No.
99-12-8
06/14/99
^ AIR CONDITIONING - "WHISTLING" NOISE HEARD
WHILE DRIVING WITH A/C OFF AT SPEEDS
ABOVE 64 KM/H (40 MPH)
^ NOISE - "WHISTLING" HEARD WHILE DRIVING
WITH A/C OFF AT SPEEDS ABOVE 64 KM/H (40
MPH)
LIGHT TRUCK:
1997-1999 EXPEDITION, F-150, F-250 LD
1998-1999 NAVIGATOR
ISSUE
A whistling" noise may be heard while driving with A/C in the Off position at speeds above 64 km/h (40 mph) on some vehicles. This may be caused by an air leak at an Instrument Panel (IP) grommet.
ACTION
Seal the IP grommet with Butyl Sealer. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
1. Verify concern.
2. Loosen IP and position away to access IP grommet (Figure 1). Refer to appropriate Workshop or Service Manual for details (IP can be loosened and positioned back slightly; it does not have to be fully removed).
3. Install a small amount of Butyl Sealer (F8AZ-19554-CA) in IP grommet (Figure 1). Use enough sealer to seal gap with P installed.
4. Reinstall IP.
5. Verify repair.
PART NUMBER PART NAME
F8AZ-19554-CA Butyl Sealer
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION DESCRIPTION TIME
991208A Seal Instrument Panel 3.3 Hrs.
Grommet
(F-Series/Expedition)
991208B Seal Instrument Panel 4.5 Hrs.
Grommet (Navigator)
DEALER CODING
CONDITION
BASIC PART NO. CODE
78044H32 07
OASIS CODES: 208000, 208999, 701000, 702300
Article No.
99-12-8
06/14/99
MPH)
LIGHT TRUCK:
1998-1999 NAVIGATOR
ISSUE
ACTION
SERVICE PROCEDURE
1. Verify concern.
4. Reinstall IP.
5. Verify repair.
Grommet
Grommet (Navigator)
DEALER CODING
CONDITION
BASIC PART NO. CODE
78044H32 07
So...
JBrew, how does this TSB come into play if it happens regardless of my AC being on or off? Not to mention the fact that my S'Crew is a 2002?
I'll check it out anyway this weekend and let you know.
Thanx for all the replies, guyz.
Originally Posted by dmallen
So...
Just thought it might help - just ignore it if you have a problem with it
This TSB could apply to you as well and later year vehicles - To me this information could be helpful with your problem regardless seeing how that's also a component of your ventilation system..
If you want to explain how the TSB's are passed , forget it .
Like I said - just ignore it then...
are you sure it's not just normal intake noise, mine whines a little at higher RPM just because it's sucking more air through that same tiny hole in the wheel well, not for long though, AF1 is goin on this summer
Whistle @ 2000 plus on accel
Hey...
This might sound crazy but here goes. Alternator bearings. I searched for months to find that squeal/whistle/chirp. tried exhaust/ intake/ HVAC and finally found a post on a forum saying it was the alternator bearings. I pulled the alternator and replaced it. No more birdies.
Had the same exact problem, drove me crazy for a couple years when somebody on this board came up with the problem and a cure. Through an inside source we found out that the flow restrictor in the heater hose was the problem. Changed the heater hose and the problem was gone. The other guy took the flow restrictor out and solved the problem...An easy way to check is to put a pair of vice grips on the heater hose adjacent to the flow restrictor and see if the noise changes or goes away.
